SEDAN - Decided to put my Z springs on the back (vs coupe springs)
Old Jul 16, 2007 | 04:56 PM
DaveB's Avatar
Originally Posted by 04NismoV35
Everything your saying is promising. I can't wait to do mine. The only difference is that I have a full Z susp w/ shocks/stuts. I wonder how different it will feel from yours.
The Z struts will be better. I wish I had them. The reason they're better is because the strut housings are about 1" shorter therefore giving you 1" more wheel travel. That additional wheel travel will go a long way in improving ride quality over rutted/broken surfaces. I will probably eventually swap on some Z struts.
Old Jul 16, 2007 | 07:57 PM
marty315's Avatar
Just put on full Z stock suspension for my 06 sedan. Ride quality is very similar although I feel as if I can take corners a little tighter w/o the floating characteristics I was getting last time. Car is obviously lower as seen below.
Old Jul 16, 2007 | 09:06 PM
STLTHSDN's Avatar
I personally prefer the look of the rear with the Z springs, i hate those lowered cars that are nose heavy. i find the z springs all around give the car a more european look like the 3 series beamers with their lower rear wheel arches.
Old Jul 16, 2007 | 11:31 PM
04NismoV35's Avatar
I'm glad to hear that, I've had dropped cars before, but it's been a while. With this car I just don't want the added harshness I've had in the past. Where do you find all this great info?
That's good news, the floatiness is exactly what I wanted to get rid of as well as lowering the center of gravity. With nearly 52K on the car the suspension has gotten very floaty and soft. NY roads don't help. Which year/version of the Z suspension do you have?
Old Jul 16, 2007 | 11:36 PM
04NismoV35's Avatar
I agree about the Euro 'tucked' look. My bro has a E46 330i and a new 335i both with KW V3 full coilovers and they look great. I'm not sure our arches are shaped right for the same look.
Old Jul 17, 2007 | 02:32 AM
Granto86's Avatar
Sure, If I end up not using them. I might want to hold on to them for a while to play around though.
Well let me know if you dont want them, I'm looking for a used set of springs, havent decided whether I should get Z or coupe ones though
Old Jul 17, 2007 | 10:48 AM
04NismoV35's Avatar
Granto86, I have gotten interest in my springs from you and someone else due to this thread. I'll give you guys a heads up when I've decided. You did ask first though.
Old Jul 17, 2007 | 11:22 AM
trey.hutcheson's Avatar
It turns out that the Z springs have a stiffer rate therefore they don't compress as easily as the coupe springs.
To clarify, the z springs should not be any stiffer. Taken from the sticky in the suspension thread(https://g35driver.com/forums/showthread.php?t=65190):
Originally Posted by Gsedan35
Just posting this to provide information for more informed choices.
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Oem springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006
Front:314 Rear:427
Old Jul 17, 2007 | 11:33 AM
Jeff92se's Avatar
Red Card Crew
That's what I was thinking Trey.
Old Jul 17, 2007 | 01:51 PM
jakeup93's Avatar
I've been on '05 revised Z suspension for over 2 yrs and I've noticed that if you load the sedan trunk with over 40-50lbs the ride on highway is surprisingly smoother on smooth/bumps/expansion joints than the regular sedan sport suspension.
Old Jul 17, 2007 | 02:25 PM
G35_TX's Avatar
Amazing the way things after you have actually tried something. Mark #2 for the 2nd time you have done this.
I've been running Z springs in the front and coupe springs in the rear for about 1.5 years (maybe longer). I put the coupe springs on the back because I had assumed the ride quality would be better and the coupe springs balance the drop since they're longer than the Z springs. Last night I was bored and decided to swap on the Z springs to see what the difference the ride quality, handling, etc would be running a full Z spring swap vs the half/half set up many of us are doing.
First, I measured the rear gap on G with coupe springs. It was about .7" with a 1/4 fuel, spare, and 40lbs of tools and softball gear. After about 10 minutes with two jacks, an 18" breaker bar, rachet, a 17mm socket, and a 17mm wrench, I had a coupe spring out. I measured the difference in height, spring gauge, and coil gap. The coupe spring is roughly .6" longer than the Z spring, is about .1" narrow in gauge, and has about an additional .6 coil. I swapped in the Z spring and moved to the other side and did the same. After lowering the car off the jacks, I was surprised to see that the gaps were about 1.5" on both sides I figured it was because of the torque load on the chassis and drivetrain after jacking up the car twice and that the car would equalize after driving for a few seconds. I rolled down the street then got out and inspected the gap. To my surprise, the gap was the exact same as the coupe springs! I drove around for an hour and tried to note the difference in handling, ride quality, etc. This is about I've noticed:
1) Ride quality is the same on most surfaces. Pavement cuts are slightly more harsh
2) Ride height in the same (measured yesterday and today after 50 miles of driving)
3) Transitional handling is quicker, less initial lean, less bouncy (nothing major)
4) Overall ride is more controlled.
Old Jul 17, 2007 | 02:30 PM
Jeff92se's Avatar
Red Card Crew
Any chance at getting this in ENGLISH?
Old Jul 17, 2007 | 02:56 PM
DaveB's Avatar
That's what I thought too, but there is clearly a difference in spring rates because it's my understanding that you can't have a shorter spring, thicker gauge, fewer coils, and then the same ride height. The springs have been on for 3 days and they haven't shown any sign of settling either. Plus, I don't think the springs would settle aways seeing that they were on a Z for over 2 years and I've never had quality springs settle.
One thing I have noticed recently is there is additional lateral movement at higher speeds when I hit rutted highway surfaces. Basically the back end is more twitchy. I really don't like that trait and it reminds a lot of what my 96 Maxima would do which is a nasty trait of beam axle suspensions which the 95-03 Maximas have. It's intersting that a IRS exhibits similiar behavior.
Old Jul 17, 2007 | 02:57 PM
DaveB's Avatar
I thought they banned you
Old Jul 17, 2007 | 09:02 PM
  #30
G35_TX's Avatar
Dream on. lol.
