Replacing wheel bolts/studs (350 z tutorial?)
Old Jul 24, 2007 | 11:39 AM
clinthammer's Avatar
Found this http://www.350z-tech.com/zwiki/Wheel_Stud_Replacement
Can I use that this weekend to replace the oem studs with longer studs? I have to use the longer studs/bolts for the 5mm HR spacer for my new wheels.
Cheers,
Clint
Old Jul 26, 2007 | 10:50 AM
anyone?
my wheels and spacers and long bolts r going on tomorrow
Old Jul 26, 2007 | 08:27 PM
G35pm's Avatar
That will work.
Old Jul 27, 2007 | 02:56 AM
THX723's Avatar
G Kreuzer
Hey Clint ... it's Clint here too!
The "hammering" of the studs out will do, but it is not the friendliest to your hub bearings (the immense shocks). The hub removal and press method is definitely preferred.
You will also find the extended length studs extremely tricky to slip back in w.o. disassembling the hub. There is very little clearance behind it. Fortunately I have managed in the past to snake the same H&R 5mm extended studs in w.o. removing the front hubs. You'll have to get it just right. The rears I cannot vouch for.
Good Luck!
Old Jul 27, 2007 | 03:07 PM
Well I did it. Its was very easy also. NO disassembly of the hub required - even for the rears.
Just remember to use a rubber mallet and turn the front wheels all the way left.
The rears according to the tech were easier. And they everything according to the linked Z tutorial - and this was even without showing the tutorial to them
Old Jul 27, 2007 | 03:41 PM
THX723's Avatar
G Kreuzer
Good to hear of the success w. the rear too.
I've only had to replace my fronts in the past.
rezendvous420
May 31, 2020 01:26 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
itschuckster
Jul 25, 2015 08:07 AM
nascarbuff17
Jul 16, 2015 10:23 AM
