Help me pick rotors for 05 G35X (I searched)
Old Jul 26, 2007 | 11:52 AM
t0pher's Avatar
I searched and found a lot of rotor suggestions but most are coupe/brembo posts.
I want to replace the front pads and front rotors with aftermarket. I have settled on Hawk HPS pads based on what I have read here. Can anyone tell me what rotors to go with? Ideally I would like to know what the "consensus" is for 05 G35X sedan owners on the board.
I am not looking for crazy expensive - just solid, reliable and good with the Hawk pads...but cross-drilled might be nice
Thanks in advance!
Old Jul 26, 2007 | 12:14 PM
seddon's Avatar
You can always pm Tony@RiversideInfiniti for stock replacement,which is what I did, he has great prices. Or you can look you R1 Concepts if you want cross-drilled. But if you have the budget check out Racing Brake.
Old Jul 26, 2007 | 12:15 PM
seddon's Avatar
If you go with the OEM replacement get the set for the 06 X, bigger rotor but you need the caliper bracket.
Old Jul 26, 2007 | 02:31 PM
killerlexus's Avatar
http://replacement.autopartswarehous...20Disc&dp=true
go with the EBC on the bottom.
Old Jul 26, 2007 | 03:51 PM
mroleg's Avatar
Based on the reviews r1concepts.com makes very good quality rotors. I have bought in the past from irotors.com and just now bought another set of 4 rotors for my 06 g35x.
Old Jul 26, 2007 | 08:48 PM
RichK's Avatar
I used the stoptech cryo slotted rotors on my 05X along with the Hawk HPS pads. Great combo and the car seems to stop much better.
Old Jul 28, 2007 | 12:38 AM
g352k6x's Avatar
MyG onDUBS
U can use the stillen slotted rotors there pretty good i have it on my 06x
Old Jul 28, 2007 | 01:36 PM
avs007's Avatar
I have the stillen cross-drilled and slotted, and am very happy with them.
Old Jul 29, 2007 | 07:34 PM
mroleg's Avatar
I just got mine installed and broke them in. So far they feel and work great. I drove about half a day on them.
Old Aug 3, 2007 | 01:33 PM
t0pher's Avatar
Okay I PM'd Tony@Riverside and am also in touch with R1concepts.
Any hookups on the board for Stoptech Cryo rotors?
Old Aug 12, 2007 | 09:19 PM
F1Flagger's Avatar
I have just installed, EBC sport slotted rotors and EBC greenstuff pads.
IFirst time using their rotors.
I have used the greenstuff pads on my Wife's Acura CL-S with Brembo "blanks".
Have gotten 50,000 out of that combination.
So we'll see how this works in my 04 Coupe.
Old Aug 15, 2007 | 02:52 PM
t0pher's Avatar
Okay - I settled on the Stoptech slotted rotors and the Hawk HPS pads. Found a great distributor in PA that is right up the street from my work too!
Thanks everyone for your help!
Old Jul 15, 2013 | 05:57 PM
christo's Avatar
Can someone confirm this? I would like to do some sort of upgrade on my 05 X because it's going through stock brakes like crazy but everything I've read says I needs ALL the hardware including calipers from an 06 X (Because 06 X has a 4-piston front caliper).
If I could keep my calipers with just a set of brackets and go to larger rotors that would be an amazing & cost effective upgrade.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
shepscrook
Aug 13, 2015 11:37 PM
1OG35
Aug 7, 2015 11:25 AM
sahizzle110
Jul 29, 2015 11:36 AM
