Do STI Calipers fit the G/350Z?
Old Aug 8, 2007 | 09:35 PM
SUB-ZERO's Avatar
I've seen a lot of factory Brembo brake kits on ebay (STI, EVO, Magnum, Cadillac) and was wondering if any of these fit the 350z/G35. The STI calipers seem to be a pretty close match but I wasn't really sure. Does anyone have any info on this?
Thanks,
SZ
Old Aug 8, 2007 | 10:16 PM
mwarsh1's Avatar
i dont think so.
Old Aug 9, 2007 | 01:07 AM
Rphillips6487's Avatar
bump!!!
Old Aug 9, 2007 | 01:59 AM
Nismo G's Avatar
It has been discussed, but i dont think anyone has actually done it...The regular OEM crap brakes have the e-brake inside the rotor. So i think with the brembos the e-brake is actually attacked to the caliper (not 100% positive on that, but i would assume thats how they would do it). So you would have to make some kind of mounting plate to fit the new calipers on, which wouldn't be that hard at all. Getting the correct rotors and everything would be the hard part.
-Sean
Old Aug 9, 2007 | 08:39 AM
G35fromPA's Avatar
The calipers may look similar, but it's hard to say whether the piston sizes would be the same.
Old Aug 9, 2007 | 09:14 AM
JessterCPA's Avatar
I do know that a friend of mine was putting STi Brembo's on his Legacy GT and the subject came up if the G35/350z units would fit. Supposedly, all the mounting points are off.
Old Aug 9, 2007 | 09:43 AM
madchef's Avatar
I've seen both disassembled, and visually they look very close.
That said, I don't think they will match up
Old Aug 9, 2007 | 06:59 PM
SUB-ZERO's Avatar
Darn! It's so freakin hard to find factory Brembo's for a reasonable price. Thank you all for the information.
-SZ
Old Aug 9, 2007 | 07:03 PM
Nismo G's Avatar
-SZ
Try it and see what happens...If all else fales you can just resell them.
-Sean
Old Aug 9, 2007 | 09:43 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Since no one has given you a definitive response...answer is NO. The closest thing between the two calipers is the color, and even then, I think the G35/350z ones have a bit more orange in them.
Old Aug 10, 2007 | 01:16 AM
StarChamp's Avatar
I have a full set of EVO VIII brembos for another project, and I can tell you they definitely do NOT fit. The g35 front caliper mounting bolts are 4" apart, the Evo's are 6.25"; the g35 rears are 4.25", and the Evo's are 5.5". Plus these are not powdercoated like the gold brembos, just painted red with a clear-coat.
Old Aug 10, 2007 | 03:15 PM
StopTech's Avatar
The short answer is NO
The long answer is NOOOOOOOOOOOOOOOOOO
The STi brembos have different piston sizes, use different pads and the mounting brackets are set up for a different rotor size and spindle.
As to the question of the parking brake, both setups use the drum in hat design as opposed to using the caliper.
-Erik-
Old Aug 11, 2007 | 10:02 PM
SUB-ZERO's Avatar
Thanks again.
-SZ
Old Aug 13, 2007 | 10:08 PM
g35ctuner's Avatar
soooo, do they fit?
Old Aug 14, 2007 | 12:26 PM
Triple8Sol's Avatar
With enough time/money/modification, you can pretty much make any bbk fit any car. As far as an easy direct bolt-on, answer = NO.
