Help Bleeding brakes
Old Aug 12, 2007 | 01:27 PM
Benny's Avatar
I have change the pads and brake lines on my 05 g35 coupe, I am bleeding the system and there isn't any air in the lines, but the pedal feels spongy. I was told there might be air in the abs module or vcs. Did anyone exprience this symtom? Do anyone knoe the procedure to remove the air in the abs/vcs module? Any help is appreciated. Thanks in advance.
Old Aug 13, 2007 | 04:02 PM
The HACK's Avatar
The dealership will need to hook up their computer to the car to make the ABS system pump out the fluid. Or what you can try and do, is get the system to cycle by activating the ABS a few times on a hard brake, then bleed, then cycle it again, then bleed, until the pedal is firm again.
Old Aug 14, 2007 | 05:50 PM
Benny's Avatar
Thanks, is there any other way to do this, just trying to cover all bases.
Old Aug 14, 2007 | 08:59 PM
Benny's Avatar
Took it for a test drive all is well. Thanks for the help.
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
