lower control arm bushings?
Old Jan 8, 2007 | 12:19 PM
robr's Avatar
Can I get just the bushings for the lower control arms? Infiniti is telling me I need to buy the entire lower control arms at $200+ each, that's ridiculous. Is there an aftermarket option? Thanks!
Old Aug 6, 2007 | 11:14 PM
TonyG35DG's Avatar
I'm having the same problem after installing TEIN basics, anyone know if it's possible to replace just the bushings?
Old Aug 7, 2007 | 09:09 AM
robr's Avatar
I never had any luck finding further info . I still need them but am just living without.
Old Aug 7, 2007 | 12:18 PM
Gsedan35's Avatar
http://www.mynismo.com/products/?id=5348&rsku=21437
Old Aug 7, 2007 | 12:24 PM
izmir41500's Avatar
G35driver Addict
+1 or try jason at riverside infiniti.
Old Aug 7, 2007 | 12:55 PM
robr's Avatar
NICE!!! Thank you!!! Wish I had found them back in Feb when my car was in the shop.
izmir41500 - unfortunately going through an Infiniti dealer isn't of much help, Infiniti does not sell the bushing as a separate part, you have to buy the whole control arm assembly if you go the dealership route.
Old Aug 8, 2007 | 12:34 AM
TonyG35DG's Avatar
Heard it'd be too much trouble to replace the bushings, takes special machine and couple hours.
robr, does the busted bushings affect your driving? My steering wheel vibrates at speeds above 50mph, still trying to figure out if it's due to the bushings or simply need a wheel balance.
Old Aug 8, 2007 | 12:11 PM
robr's Avatar
I can't really say how it affects the ride, I bought the car in Feb and as part of my pre-purchase inspection, it was pointed out to me that I needed new bushings. I do have a slight vibration as well at certain speeds, but I think I've read in these forums that it's somewhat common.
Interesting to hear that perhaps the amount of labor required to replace the bushings might not make financial sense compared to just buying new control arms.
Old Aug 8, 2007 | 12:15 PM
gqong's Avatar
tony@riverside got me one. check with him hes the man!
Old Aug 8, 2007 | 06:07 PM
TonyG35DG's Avatar
ggong, did you get just the bushings? Do you have Tony@riverside's contact info? I'm hoping it's just one of the lead weights falling off the wheel during installation, which can be solved by simple wheel balancing.
Old Aug 13, 2007 | 09:56 PM
g35ctuner's Avatar
mine are starting to crack too.. that little arm that attaches to the chassis the rubber bushing on that seems to be tearing as well, only 40k miles on the car wth
Old Aug 13, 2007 | 10:09 PM
GLuXuRy's Avatar
i know on some BMW's you can press out the old bushing out of the arm .. but on the new 7 series you have to replace the whole arm
Old Aug 14, 2007 | 11:49 PM
bigugly78cj5's Avatar
thanks for the link gsedan, ive been searching for replacement bushings since i got my 20s.......and does anyone have this tony@riversides contact info?..... and hey gqong the part tony got you, what was it for? and did it come in a nissan marked bag/box? if so whats the part number?.... also does anyone know which part in particular this is? INFINITI G35 2003-2006 Front Lower Transverse Link Bushing ?? i dont need the upper control arm nor the radius arm, but i need the lower control arm bushings is this it?.....
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
nineiron
Sep 10, 2015 12:08 PM
erickLA
Aug 18, 2015 04:46 AM
smokey2
Aug 14, 2015 03:07 PM
