19x10.5 +23 - Will 275/30/19 be OK?
Old Aug 13, 2007 | 11:32 PM
TakaBlackG35's Avatar
Hey guyz, currently I got the 19x9.5 +28 245/35/19 up front and 19x10.5 +23 275/35/19 in the rear with TEINs 350z htechs. Question is would 275/30/19 be ok in the rears? I see a lot of packaged deals with 245/35/19 up front and 275/30/19 in the rear...just wondering if these would look ok or if there will be a noticable gap. I always wondered why they went with 30's instead of 35s. I was searching quite a bit, but couldn't find anything concrete. TIA for your responses!
Old Aug 13, 2007 | 11:35 PM
Calvin's Avatar
Overglorified Altima
stick with 275/35 or 285/35.
Old Sep 16, 2007 | 01:33 AM
g-spot26's Avatar
If you are wondering how the size changes between a 30 and 35 aspect ratio, use a calculator like this one:
http://www.1010tires.com/TireSizeCal...?action=submit
Old Sep 16, 2007 | 03:22 AM
empfl's Avatar
personally i like the 35 series/ safer imo.. 30's pretty thin especially when you are running 19's
Old Sep 16, 2007 | 11:06 AM
escobar929's Avatar
275/30 is only for 20's. for 19's use 275/35 as other have said
Old Sep 16, 2007 | 11:41 AM
Nismo G's Avatar
285/30/19 will be fine. It will give you a little beef and no stretch.
-Sean
Old Sep 16, 2007 | 01:20 PM
ltrrtl218's Avatar
go with 275/35. though i like the lo pro sretched look of the 275/30
Old Sep 16, 2007 | 01:35 PM
Nismo G's Avatar
I disagree - if you are going to have a rim and a performance car...put a tire that fits. A 275 tire is not going to cover the whole rim and is going to perform like ****. If you hit any pot holes the out lip of your rim is going to either get bent or scratched to hell. That is why they make tires that have little bit of lip protection that covers that outer edge lip. a 285/30/19 is going to be a stretch fit as it is. I would really go with a 295, but a 285 will be fine - it is still within spec of a 10.5 rim.
-Sean
Old Sep 16, 2007 | 02:28 PM
lowrider's Avatar
-Sean
This, again, is bogus information. With a 275/30/19 or a 285/30/19 you'll kill the stagger and give the VDC fits. You need 275/35/19 or 285/35/19. The car was designed and expects to see about a one inch difference in OD between the front and rear tires. You see so many deals on the 35 series front and 30 series rear because they were designed for cars without the stagger, like the BMW. Keep the stagger. BTW, with the 245/35 up front, use 275/35. With 255/35 up front, use 285/35. Either combo will fit your width rims. I wouldn't go wider with you offset, you may rub. As it is, 285s will be close.
Lou
Old Sep 17, 2007 | 04:10 AM
G-MENTED's Avatar
Lou
good info
KruZZe
Feb 27, 2023 05:04 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
