FYI - Camber off with Eibach
Just got an alignment done with Eibach pro-kit on. I knew the fronts would be a little of but was surprised at this.
Just FYI, the fronts are -1.5 left and -2.0 right.
Looks like I will need a front camber kit for the front now with only Eibach Pro-Kit on.
Every spring that lower oem ride height creates excesss camber and shifts the STATIC angle of the suspension mounting............also creates a different bumper steer toe curve angle.
factory camber is around -1.5...why be so paranoid?? you will be fine...remember..you sit on the driverside...thats an extra XXXpounds that will be sitting on that side
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
