Spacers 15MM or 20MM
Old Aug 21, 2007 | 03:31 AM
I Scare's Avatar
I am trying to decide if I need the 15mm or 20mm. Any recommendations anyone? I've searched, but the offsets are different for every wheel. And I can't seem to find the answer I am looking for. From the look of the picture below, what size do you think I need for the Axis Penta wheels? They're front 8.5 and rear 9.5. I am trying to work something out with Tonystarks79.
Old Aug 21, 2007 | 03:33 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
15 if you want it to be flush, 20 if you want it to be aggressive.
-GP-
Old Aug 21, 2007 | 12:22 PM
barrettbenson's Avatar
I have an 04 coupe with brembo brakes. Would 15mm spacers help my wheels be flush? Where do you get them, and how much are they usually?
Old Aug 21, 2007 | 01:54 PM
PEtaG35's Avatar
^ It all depends on your current wheel off set
Old Aug 21, 2007 | 03:03 PM
I Scare's Avatar
So for my offset, 8.5 x 9.5 , tire: F275/40/19, R275/35/19. 15mm should do just fine? Just wanted to reinsure before I buy. Thanks for your help.
Old Aug 22, 2007 | 03:23 PM
GReddySetGO's Avatar
What is your OFFSET?
Old Aug 22, 2007 | 03:29 PM
I'm pretty sure your offsets are +35 all around or +35F/+45R, but it looks more like +35 all around from the picture. I'd go with +20mm spacers front and rear.
-GP-
Old Aug 22, 2007 | 04:01 PM
redlude97's Avatar
I personally would go 25-30mm all around
Old Aug 22, 2007 | 04:02 PM
G35kidd's Avatar
Yeah i have stock coupe 18's and im going with 25mm all around
Old Aug 22, 2007 | 04:20 PM
robzone's Avatar
25mm.
Old Aug 22, 2007 | 07:12 PM
You're only gonna get a bunch of mixed opinions until you let us know your exact offset the wheels are.
Old Aug 22, 2007 | 07:48 PM
TonyStarks79's Avatar
Hey guys this is my set up..275/30/19x9.5 +25 in the rear 245/35/19x8.5 +29 in the front...I ordered a 15mm spacer but debating to go more for the aggressive look..Do you think 20mm would work without having to roll any fenders?
Old Aug 22, 2007 | 09:06 PM
^ Are you the original poster under a different sn?
If those sizes are what is pictured above, I would go with 20mm spacer in front, and 15mm spacer in the rear.
Old Aug 22, 2007 | 09:32 PM
No..I'm not..my setup is different to I Scare..I just happen to have a hook up for some spacers..
Old Aug 22, 2007 | 09:34 PM
I see... the pic above looks really tucked, I wonder what his offset is.
