H-tech front/S-tech rear?
Old Aug 23, 2007 | 11:39 AM
617G's Avatar
CFW (Carbon Fiber Whore)
For you suspension guru's...since I already have a set of S-techs for the G, could I run the 350Z H-techs for the front, and G S-techs for the rear instead of doing the springmount mod? How do the springrates compare? Thanks.
Old Aug 23, 2007 | 12:05 PM
redlude97's Avatar
if you had 350z-stechs I would have said you woul be fine, but the g35 s-techs are just way too soft in the rear IMO. They have a springrate of 274, compared to the h-techs which are 375. Stock is 342 or 427 depending on year/options
Old Aug 23, 2007 | 12:09 PM
izmir41500's Avatar
G35driver Addict
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006
Front:314 Rear:427
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Old Aug 23, 2007 | 12:17 PM
617G's Avatar
thanks...that's the info i needed!
Old Dec 31, 2007 | 08:21 PM
giorgio_g's Avatar
so i am looking to lower my car its a 05 g35 coupe wich one do u guys recommend me to use? tein s or tein h?
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Popes
Jul 29, 2015 05:07 PM
