S-techs and sport shocks
Hey,
On my 05 sedan, i have unrevized z springs w/ sport suspension shocks and its no problem, but i want to go lower.
My question is.... would my sports suspension/shocks survive if i put in tein s-techs? or would they blow out or bottom out...
they will go out eventually. The cheapest way is to get used z-shocks. I have been running on s-techs and Z-shocks for over 2 years and havent experienced any type of bounciness or floating.
i thought the sports suspension was pretty much the same as the z shocks?
or at least, you could youse the sports suspension with z springs, so i am assuming that the sport shocks would be the same as the z shocks?
Anyone with more knowledge chime in.
hey thanks for the info, if i do decide to use z shocks i will be sure to get 05-07. but anyway, would i be able to use s-techs with my sport suspension shocks without the shocks bottoming out or basically "dying"?
Originally Posted by Gsedan35
Spring rates aren't high enough to be a issue. Removing 2" of front shock piston stroke is however. IMO, give yourself back 3/4" of piston stroke with the 05/07 Z shocks or upgrade to D-specs.
i honestly dont know what that means... r u saying i CAN use the sport shocks but the z shocks are a better option? i dont want to get d-specs, if i cant use my sport shocks or z shocks, i think i may just get tein basics.
"Would i be able to use s-techs with my sport suspension shocks without the shocks bottoming out or basically "dying"?
Spring rates aren't high enough to effect the shocks so they won't be dying, not enough stiffness to cause that. On the bottoming out question, your wanting springs that remove 2" of front shock piston stroke, installing the Z shocks would not only give you back 3/4" of that lost stroke. Also forgot to mention that the Z shocks are firmer, that will also help keep you off the bumpstops.
