Anyone know anything about these?
http://www.ichibausa.com/ic35g35caarm.html
How much postive/negative camber adjustment they allow, quality, etc.
Looks a whole lot better then the Megan or Pro1 arms. I wold think they would mirror the cusco's in adjustment range.
I called j-ondemand, who supplies them, and they said it offers +4mm in positive adjustment. How many degrees is that equivalent to? Is it comparable to the cuscos?
FGC President
wow those look very nice.
i am callin my suppllier right now to find out somemore info on them.
they look to be slide design similar to the 350evo's. hopefully it will give a decent amount of correction.
i will post more when i get off the phone
FGC President
ok
the number to ichiba is busy so ill keep calling to get more info
i can get the fronts for 296 plus shipping and the rears for 129 plus shipping.
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
sounds pretty good they dont looks as solid as the 350 evo arms tho
FGC President
ok more info
the fronts have adjustment of +/- 2.5 degrees so a range of 5 degrees.
the rears have adjustment of +/- 1.5 degrees so a range of 3 degrees.
i informed them about the website not displaying that info and he said he would have their webmaster update it ASAP.
front
rear
also i asked about wholesale account and they said that they are available, but need a 2k buyin or a 3k buyin. so if there was interesting in doin a group buy on these, could possibly become a dealer or distributor for them. which would mean i could get better pricing. let me know if anyone is interested in doing this.
front
Quote:
Part #:......NS-20021F
MSRP:.......$359.00
Our Price:..$359.00
currently i can get the fronts for 269 plus shippingOriginally Posted by Ichiba
Introducing the Ichiba front and rear adjustable camber arms for your 350Z and G35. Ichiba front and rear adjustable camber arms are direct replacements and allow you to adjust camber on the front and the rear of your 350Z or G35. These arms uses a special compound rubber bushing to ensure smooth operation and minimize noise. No more premature tire wear on your expensive set of wheels! And better handling too!Part #:......NS-20021F
MSRP:.......$359.00
Our Price:..$359.00
rear
Quote:
Part #:......NS-20021R
MSRP:.......$149.00
Our Price:..$149.00
currently i can get the rears for 129 plus shippingOriginally Posted by Ichiba
Introducing the Ichiba front and rear adjustable camber arms for your 350Z and G35. Ichiba front and rear adjustable camber arms are direct replacements and allow you to adjust camber on the front and the rear of your 350Z or G35. These arms uses a special compound rubber bushing to ensure smooth operation and minimize noise. No more premature tire wear on your expensive set of wheels! And better handling too!Part #:......NS-20021R
MSRP:.......$149.00
Our Price:..$149.00
IMO, remove 2 degree's from their front numbers and you have a actual adjustment range, Using the same design as Cusco, their's no way they are going to adjust that much range. +.5 to -2.5 is much more within reason.Originally Posted by SFLG35
ok more infothe fronts have adjustment of +/- 2.5 degrees so a range of 5 degrees.
FGC President
hmm i see. not tryin to argue as i dont really know, but that is what the guy at ichiba told me on teh phone today. i had a hard time believing it as well, but thats what he said.
i thought the cusco one only had set adjustment points as in they couldnt slide back and forth.
Quote:
+1, its impossible to get more than ~+1 degree of positive adjustment on the front without the SPC spacers because there just isn't clearance for the added length of the camber arms in the fender wellOriginally Posted by Gsedan35
If these really do offer that a good range of pos adjustment, I'd definitely be interested in a group buy in. Let me know how to get them from u. Can u adjust the toe with the rears too like the SPC? Thanks.
front
rear
front
rear
i'm interested too w/ that price. let us know. i've been holding off purchasing the SPC front A-A arms.
