what pads last longest for brembos?
Old Sep 5, 2007 | 02:43 AM
steeb's Avatar
my front pads are almost done and ive only driven like 7,000 miles since i changed them. im guessing if im lucky ill get 10,000 miles out of the fronts. i have not checked the rears yet. i did do a track day at streets of willow but im a beginner so i wasnt going to fast. also like 10-15 canyon cruises. this car is currently my daily driver and i usually drive very conservatively so even with a little bit of spirited driving in the mix id say 10,000 miles out of brake pads is a bit excessive....
do brembo pads last longer than axis ultimates? is there other pads that last longer with the performance?
Old Sep 5, 2007 | 06:57 AM
g35rcr's Avatar
my project mu type ns pads have lasted 30k miles and i have 50% left still
Old Sep 5, 2007 | 07:32 AM
G35fromPA's Avatar
Brake pads are a tradeoff:
Great initial bite and cold braking power = high dust and short life
High fade resistance, long life and low dust = weaker initial bite and cold braking power
Personally, I'd rather spend the $140 on Brembo OEM pads every 3 years - they're not hard to change. Another option for you is to get a dedicated track pad (and maybe even rotors if you want to get fancy) and pop those in and out for track days.
Old Sep 5, 2007 | 10:36 AM
steeb's Avatar
G35fromPA
brembo every 3 years? how many miles do u get out of the brembos? i cant tell which dusted more. i never did any track days with brembo pads so i dont know if they are better than the axis ultimates which are better.
g35rcr
axis ultimates are only $110 bucks for front and rear. im going to have to research these project mu pads.... how come these have lasted you so many miles?
thanks people!
Old Sep 5, 2007 | 11:36 AM
g35rcr's Avatar
project mu pads are great pads...axxis are nice for the price
Old Sep 5, 2007 | 03:41 PM
j-ondemand.com's Avatar
endless makes a nice pad. It's a toss up of either Project Mu or Endless
martin
Old Sep 5, 2007 | 05:06 PM
steeb's Avatar
well for the price the project mu pads is good even tho more expensive than the axis ultimates if they last longer. how is the performance compared to axis ultimates?
Old Sep 6, 2007 | 08:54 AM
Q45tech's Avatar
Impossible to compare pads using miles driven because every situation is diffferent as to applications per mile and number of fractional seconds per application.
Unless you use 2 cars and they closely follow each other for every mile in 20,000 miles.
Old Sep 6, 2007 | 10:41 AM
G35fromPA's Avatar
Originally Posted by steeb
G35fromPA
Well, 3 years is for me and so far I'm almost at 17k miles on my original OEM brembo pads. By my calcs, I should get another 3-4k out of the fronts, though, and longer out of the rears.
Old Sep 7, 2007 | 02:08 AM
steeb's Avatar
so if i were to go from hawk hp+ to hawk hps i should get longer pad life but a decrease in braking performance? im thinking of switching to hawk hps but i really love how the axis ultimate pads totally screech lfreakin loud!!! do the hps pads squeak?
Old Sep 7, 2007 | 02:12 AM
superdds's Avatar
30k, mostly city. still have about 5mm or so left on my original 04 brembo pads.
Old Sep 7, 2007 | 12:22 PM
fortified's Avatar
lower speed bite is less, esp cold from what I've read on here and other forums. But fade and dust should be less, I hear the same complaints about squeaking. But installation technique as well as rotor condition and break-in can be factors too.
It seems I read the fewest complaints about Project Mu and also Satisfied street pads tirerack sells. But only a handful of people seem to have them.
Old Sep 7, 2007 | 12:29 PM
g35rcr's Avatar
hawks suck when its cold and if you get the wheel submerged in water...
Old Sep 7, 2007 | 05:21 PM
G35fromPA's Avatar
HP+ is more of a track pad = higher heat handling and fade resistance, but need to be warmed up more.
HPS is a street pad = slightly lower heat handling and fade resistance, but still need to be warmed up a bit.
HPS should have a bit better initial bite on the street than HP+, should squeal less and be easier on your rotors than HP+. Still, I was never happy with the HPS in a Northeast climate. My HPS on my 300zx never squealed, but I also bedded them properly, which can play a role.
Old Sep 8, 2007 | 12:59 AM
steeb's Avatar
so hps would also last longer but have less bite than the axis ultimates and last longer.... i think im gonna try the hps pads instead of the ultimates. thanks everyone
btw, i love how my ultimates squeak like train brakes, im gonna miss people closing their windows at stop lights
