Tire Pressure Monitor ????
Old Sep 17, 2007 | 10:56 PM
ibelonginprison's Avatar
Resident G35Driver Pirate
tire pressure drops when it gets colder. You slowly lose air. And no, it doesn't go BACK when it gets hot.
Old Sep 18, 2007 | 12:01 PM
jgainnm's Avatar
[QUOTE=txgcoupe]I put 34psi in the wife's coupe and it rides like ****. Put them at 31psi.
John
QUOTE]
The recommended pressure for the 19" tires is 35 psi.
Old Sep 18, 2007 | 02:44 PM
txgcoupe's Avatar
Look at the photo... they're 17".
John
Old Sep 19, 2007 | 11:18 AM
VISHAL_G35's Avatar
newb question
do the 03 g35's have the tire pressure monitors?
Old Sep 19, 2007 | 11:36 AM
rob40wilson03's Avatar
For a gas, Pressure = Temperature * gas constant
therefore, lower temperature means less pressure and vice versa
when it gets cold, **assuming your tires are losing a negligible amount of air**, the pressure will drop, but then will return when it warms up
also, i believe the car must be driven at a minimum of 16mph for the sensors to reset, but like others have said, it takes a minute or two but you do have to be above 16mph
Old Sep 19, 2007 | 12:10 PM
jgainnm's Avatar
John
Very true, but judging by the original poster's options, I expect he has 19".
Old Sep 19, 2007 | 12:41 PM
DTG's Avatar
DTG
I have the OEM 18s and I was on a long distance drive yesterday and the light was on the whole time. I did not check the pressure but the tires looked fine. Also, I have a lot of negative camber... could this cause the light to come on because the tire is not sitting properly to the ground?
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
