Tire Pressure Monitor ????
Old Sep 15, 2007 | 12:39 PM
Shan's06G35's Avatar
Newb question. How much pressure does a tire have to lose before it sets off the Tire Pressure Monitor warning light? The warning light on my wives 06 coupe went off this morning and I found one tire about 4 psi low. I filled all the tires to the same pressure and it is still on. Does it take a little while for the light to reset?
Old Sep 15, 2007 | 12:43 PM
2K5-G35-C's Avatar
Yes it took mine about five minutes of freeway driving before it went off for me. The TPMS is very sesitive tho it drives me crazy...
Old Sep 15, 2007 | 12:53 PM
Beebo's Avatar
I Think It Comes On At 30 Psi After You Put Air In The Tires It Takes 5 To 10 Min To Turn Off
Old Sep 15, 2007 | 03:01 PM
LjN_728's Avatar
Tires should be at minimum 35psi (Check the sticker on the door jam)...the tpms light should go away within 1/4 mile.
Old Sep 15, 2007 | 04:07 PM
V35 Skyline GT's Avatar
6MT Coupe
Mine went off at 22-23psi.
As said...light will eventually go out after psi's are back up and drive awhile.
35psi cold is the correct amount.
Old Sep 15, 2007 | 04:40 PM
35 psi is what I have in them now.
Old Sep 15, 2007 | 07:28 PM
Memphoman's Avatar
should come on at 27 PSI with a nominal pressure system of 35 PSI.
Old Sep 16, 2007 | 09:17 PM
daveblank's Avatar
Your guage could be inaccurate. Try another one & see if you get the same readings.
Old Sep 17, 2007 | 09:11 AM
filthyg35's Avatar
correct...I had a slow leak for awhile and light was coming on at 26-27..but after I filled to 35....light go off in 1min...I always waited for the light to go out...that damn alarm scared the **** out of me the first time...
Old Sep 17, 2007 | 10:02 AM
watsgoodG's Avatar
mine went off at around 26 does it have anything to do w/ the weather?
Old Sep 17, 2007 | 12:10 PM
LjN_728's Avatar
Yes...at times the tpms will alarm in the morning and go away by noon due to the warmer temp and pressure building up. That's why it's best to check the tire's pressure the first thing in the morning before any driving.
Old Sep 17, 2007 | 06:08 PM
jgainnm's Avatar
Yes. We can get some quick moving low pressure systems thru here, and every time my sensors have gone off has been just after one of those storms. I was usually at about 30 psi in one or two tires.
Old Sep 17, 2007 | 07:10 PM
VanQuish's Avatar
what i usually do, i just try to fill it up slightly more than the max psi rating. when i did that, i never had any problems getting those pesky warning lights.
Old Sep 17, 2007 | 10:37 PM
txgcoupe's Avatar
I put 34psi in the wife's coupe and it rides like ****. Put them at 31psi.
John
Here is the pressure sticker:
Old Sep 17, 2007 | 10:45 PM
express705's Avatar
i keep mine at 46...
