Brake Squeals.....
Old Oct 3, 2007 | 08:21 AM
reverse's Avatar
Brake Squeals.....
I've notice my front brakes (Brembo) are squealing when I come to a slow rolling stop. Friend of mine checked the pads & they were fine. I was thinking maybe the shims need to be replaced or something. Any suggestions?
Old Oct 3, 2007 | 05:09 PM
G35fromPA's Avatar
Hi-perf pads sometimes do that on slow stops. But, you can try re-bedding them - that might help. Alternatively, you can take the pads out and apply some more Disc Brake Quite to the backs of the shims.
Old Oct 3, 2007 | 06:16 PM
reverse's Avatar
appreciate that......its a little embarrasing
Old Oct 4, 2007 | 02:18 PM
deanfootlong's Avatar
welcome to owning a G with brembos. I love them but i hate them beacuse they are squeaky as hell. I've tried disc brake quiet and grinding down the surface of the pad to take off what i thought was a "glaze" on the pad ; still nothing changed. any thoughts?
Old Oct 4, 2007 | 03:37 PM
dothemath's Avatar
Re-bed the brakes. It always works for me.
Old Oct 8, 2007 | 11:54 PM
what do you mean? just take them out and put them back in? I did that with my fronts and it didnt do anything. thanks for the thoughts tho.
Old Oct 9, 2007 | 12:20 AM
terrycs's Avatar
White paper on bed-in procedure:
http://www.stoptech.com/tech_info/wp...contents.shtml
Old Oct 9, 2007 | 02:46 PM
thats in informative link. however, how about re bedding used pads? same thing? i want to get rid of my brake squeal BAD.
Old Oct 9, 2007 | 05:37 PM
dothemath's Avatar
yes....same thing.
Old Oct 10, 2007 | 04:18 PM
Q45tech's Avatar
Well it can only be vibration [squeel frequency] from pads or rotors............something has worn and or changed. Try disassembly and cleaning of calipers, pins, and antivibration shims with new lubricant [Nissan oem shim-grease].
Do an extremely light cut [few thousanths] on rotors to expose the metallurgy and rebed [transfer brake film] to rotor.
Old Oct 11, 2007 | 02:54 PM
bocatrip's Avatar
If all else fails, switch to ceramics.
Old Oct 11, 2007 | 07:20 PM
Q45tech's Avatar
Oem are ceramics inthat they have more non metal than metal %.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
