Cracking Crossdrilled Rotors!>
Old Oct 16, 2007 | 06:12 PM
PEARL-G's Avatar
What is all of this garbage i keep hearing about crossdrilled rotors cracking?? i want to buy the stage 2 stoptech upgrade kit but every shop is talking me out of it!!WHY!!!!!
Old Oct 16, 2007 | 06:15 PM
Jeff92se's Avatar
Red Card Crew
Because they are prone to cracking.
Old Oct 16, 2007 | 06:16 PM
PEARL-G's Avatar
really, i thought that was all crap depending on the brand and quality
of rotor
Old Oct 16, 2007 | 06:17 PM
redlude97's Avatar
of rotor
It is dependent on the brand and quality of the rotor, but they are all still more prone to cracking than blank rotors
Old Oct 16, 2007 | 06:23 PM
PEARL-G's Avatar
if they are prone to cracking why do all exotic cars use them
Old Oct 16, 2007 | 06:24 PM
PEARL-G's Avatar
does anyone here use stoptech??
Old Oct 16, 2007 | 06:26 PM
Jeff92se's Avatar
Red Card Crew
Because the exotics feature CAST in holes vis drilled in holes. Drilling the holes creates stress risers that lead to cracking. Ever wonder why the cracks start from the holes?
Also exotics probably change the rotors way more often mileage wise.
You can run drilled if you want. Won't net you any measurable gains on the street and you run the risk of cracking and if they warp, you can't turn them
Old Oct 16, 2007 | 06:27 PM
PEARL-G's Avatar
yeah my car is just street nothing fancy, ill check out slotted i guess
Old Oct 16, 2007 | 06:45 PM
AthensBlueG's Avatar
Brian
Interesting thread, I didn't know about the potential of cracking, nor about the higher quality cast rotors used by exotics.
Filled my learning quota for the day!
Old Oct 16, 2007 | 06:46 PM
PEARL-G's Avatar
I Know I Just Want To Buy Some Da&% Rotors!!!!!
Old Oct 16, 2007 | 07:38 PM
Gday's Avatar
instead of cross drilled, get slotted rotors.
Old Oct 16, 2007 | 07:42 PM
Alan's Avatar
shrug i run stoptech drilled just fine. then again, they havent seen any track days.... it seems that if you want hardcore performance, get a solid or slotted rotor. i went with drilled because they look good and stoptech makes good stuff.
Old Oct 16, 2007 | 07:44 PM
savefatkids's Avatar
just get slotted. they look just as nice and perform better
Old Oct 16, 2007 | 07:47 PM
O HELLA OEM's Avatar
damn was thinkin about gettin crossed drilled rotors nvm...goin to get slotted now thanks
Old Oct 16, 2007 | 07:57 PM
Gday's Avatar
I know a shop in Cali that purchased brembo blanks and drill/slot them themselves and some automated machine. i don't trust anything coming from them.
even though the process is probably similar used by brand name companies, i'm guessing there is a 2nd step after the drilling. Such as some type of "heat" treatment to make it stronger.
