Dont want feathering agian, will SPC Front Arms prevent feathering?
Old Nov 3, 2007 | 08:34 AM
  #31
wadd3456's Avatar
I think we've gone way out on a tangent. All Im looking for is 1 person to step u and say "yes, these SPC arms helped my wear issues immensely."
Old Nov 5, 2007 | 05:55 PM
  #32
bocatrip's Avatar
Sorry to have to say............"Don't hold your breath"
Old Nov 7, 2007 | 10:43 AM
  #33
Q45tech's Avatar
Correcting and bring back camber to NOMINAL will help camber wear, and toe wear BUT feathering is a totally different situation as mostly a direction tire problem regardless of camber or toe..........camber and toe can make heel toe feathering worse.
Just as with odd heel wear on human shoes the problem gets solved by buying new shoes.
Lowering even with adjustable arms CHANGES the camber and toe curve not the shape of the curve just where the suspension sits nominally on the curve since the suspension attachment points on the body are lowered thus the angles change.
Why one uses tie rod end spacers to fix the angle of the tie rods to correct the bump steer angle.
Old Nov 7, 2007 | 05:57 PM
  #34
wadd3456's Avatar
Q45, in theory I agree 100%. Its unfortunate that (once again) no one has proof that this actually works with swapping out arms.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
socalg35x
Aug 7, 2015 09:36 AM
TheefrshstVQ
Jul 26, 2015 09:37 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
