2006 M45 OEM wheels on 2005 G35 Coupe?
Oct 25, 2007 | 03:48 PM
All:
I have a 2005 G35 Coupe with the standard 17" wheels, no sport package, no Brembo Brake Kit. I have the opportunity to purchase a set of 2006 19" OEM M45 wheels, but is wondering if I will have problems with the specs:
wheel 19/8.5 offset 45mm
tires 245/40r/19
I have heard I may need to use 10mm spacers for this configuration on the front wheels - are there pro/cons in using spacers?
Thanks in advance.
Lewis
Reply 0
Oct 26, 2007 | 01:14 AM
you will probably need bigger spacers to make it look more flush on a coupe. the sedan guys usually use a 10mm spacer. I think coupes need a 20 or 25mm spacer
try searching for this, its been talked about a lot.
Reply 0
Oct 26, 2007 | 02:03 AM
Thanks for the quick response... my main question is what the pros (aesthetics) and cons (rubbing?) of spacers... and more importantly has anyone done this before, so I know what exact spacers to get?
Reply 0
Oct 26, 2007 | 02:10 AM
I run M45 sport wheels
25+mm spacers on front and rear
245/30/19 front 255/40/19 rear
No rubbing no nothing
https://g35driver.com/forums/picture-share/134539-05-ip-g-m45-wheels-awesome-looking-ride-pix.html
Reply 0
Oct 26, 2007 | 07:16 AM
Quote: Thanks for the quick response... my main question is what the pros (aesthetics) and cons (rubbing?) of spacers... and more importantly has anyone done this before, so I know what exact spacers to get?
H&R 25mm Spacers
Reply 0
Oct 26, 2007 | 09:37 AM
Correct me if I am wrong, but the m45 wheels are a 50 offset
Reply 0
Oct 26, 2007 | 12:47 PM
^who cares
Reply 0
Oct 30, 2007 | 09:53 AM
+50mm offset on the M wheels. I'm running them as well.
I used +25mm spacers and still not quite as flush as I would like.
I'm lowered on 350Z Tein H Techs and I have 235/35/19 fronts and 255/40/19rears, no rubbing.
Reply 0
