OEM Brembo Brakes '03 G35
Old Oct 26, 2007 | 11:41 PM
miki9478's Avatar
Brakes OEM Brembo Brakes '03 G35
Wow are they expensive!
Does anyone know the minimum rotor thickness for the Brembo rotors? Can they be re-cut?
Any cheaper alternatives without sacrificing too much performance?
Old Oct 27, 2007 | 09:17 AM
G35fromPA's Avatar
Minimum thickness is 28.4mm. They can be recut, but not more than once. There are aftermarket alternatives, however. Do a search on here, and check out everythingg35.com, mynismo.com, tirerack.com
Old Nov 6, 2007 | 02:01 PM
miki9478's Avatar
Question Slotted or Cross-Drilled
Which is better for day to day street driving, Slotted or Cross-Drilled? The OEM's don't have either.
Old Nov 6, 2007 | 02:14 PM
LazerRed1's Avatar
Opinions will vary, but I'd go solid for street. Slotted after that.
Old Nov 6, 2007 | 02:25 PM
miki9478's Avatar
I'm not sure where to find solid rotors on-line. Anyone have an idea? The dealer pricess are way too high.
Old Nov 6, 2007 | 03:15 PM
G35fromPA's Avatar
Everythingg35.com carries the Centric solid rotors for $75/pc. Centric bought Stoptech last year, so they should be decent rotors, especially for the price.
Old Nov 6, 2007 | 05:06 PM
Triple8Sol's Avatar
I've always gone for xdrilled/slotted for looks and performance. No problems yet.
Old Nov 7, 2007 | 12:38 AM
OG35Driver's Avatar
Brakes
I installed drilled Brembo rotors, Nismo pads, Goodridge steel braided lines, and upgraded to Motul brake fluid to compliment my OEM Brembo calipers and wow what a difference. Already have 30k on the pads and there is still over 60% pad life left. Driven very hard too. Rotors will run about $350 for front and $300 for rear, but well worth the price...
Old Nov 7, 2007 | 11:00 AM
dothemath's Avatar
Save some more money and do the job yourself
https://g35driver.com/forums/brakes-suspension/182516-project-mu-rotor-stoptech-ss-lines-nismo-pad-installation.html
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
