Cannot Decide on Drop!
Old Nov 6, 2007 | 09:24 PM
SteveBlake's Avatar
Ok I'm goin for a drop now, im running the OEM 19's and i want a good looking drop. I was thinking 350z H Techs but the drop on them only looks "dropped" with aftermarket wheels IMO. Also thinkin about doin G35 Tein S Techs on some aftermarket shocks like another member on here because he did not need a camber kit. On top of that i wanna run some spacers on it with the drop so the wheels sit flush with the fenders. Which drop would look the best with the OEM 19's and spacers?
Old Nov 6, 2007 | 09:34 PM
gary c's Avatar
Mind maker upper.......!
Ok, you can install the 350Z H Tech springs and not spend major $ because
you won't need anything more than an alignment. If you go with the S Tech
springs you'll need everything in the book to bring you G back to factory
specs. With either spring you should replace the OEM shocks with a quality
ajustable shock like Tokicos.
Old Nov 6, 2007 | 09:46 PM
SteveBlake's Avatar
If i get the 350z H Techs and the tokicos can i adjust the rear so it is just as low as the front?
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Rose M
Oct 12, 2015 10:00 AM
