Question!
Old Nov 7, 2007 | 10:58 AM
MixturePinoy's Avatar
Brakes Question!
If I get new rotors and pads do i need to upgrade to steel braided lines? I'm planning on purchasing non brembo stoptech slotted rotors and hawk hps pads. I have a 5at slightly modded and i don't track the car. Is braided steel lines super necessary? Thanks
Tito
Old Nov 7, 2007 | 10:59 AM
Calvin's Avatar
Overglorified Altima
no.
Old Nov 7, 2007 | 11:01 AM
chobble19's Avatar
u dont have to change them but u should. oem lines suck! you can find a set of agency power braided lines in ebay for a decent price. i even got rid of my oem clutch line and relpaced it with a braided one since they tend to stretch/flex..
Old Nov 7, 2007 | 02:32 PM
Scrooge's Avatar
You don't need too. The Oem would work. You can get the SS brake line if you want better peformace out of the brake's. Also if you do get them. Flush your system first before installing them.
Old Nov 12, 2007 | 01:28 PM
Okay. another question... How long do rotors last? I've had the same ones on from the factory for 77k already. do i you they need replacing?
Old Nov 27, 2007 | 01:11 PM
gte959s's Avatar
check your rotor thickness with a micrometer. there are spec thickness that the rotor should stay between.
30mm is standard and you can run them around 28mm
the measurements should also be within 0.015 mm of one another across 5-10 positions.
Old Nov 27, 2007 | 02:48 PM
Triple8Sol's Avatar
My guess is that your rotors are just fine. How many times have you had them resurfaced?
I don't think you should bother with ss lines, since you have non-brembos and drive like a pussy.
Old Nov 27, 2007 | 02:55 PM
lol.. f a g
Old Nov 28, 2007 | 07:14 AM
Triple8Sol's Avatar
Let me confirm...your shifter looks like this, no?
Old Nov 28, 2007 | 10:21 AM
nope. mine is tan
Old Nov 28, 2007 | 11:14 AM
Triple8Sol's Avatar
My bad, you sportshifter, you...
Old Nov 28, 2007 | 11:18 AM
So.. is your shifter titanium?
Old Nov 28, 2007 | 11:24 AM
MIA BlazinVQ's Avatar
brb getting cut
PWNED!!!
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
