!!! Emergency Brake Please Help !!!
Old Nov 13, 2007 | 12:21 PM
skyhorse's Avatar
I needed to replace my brake pads for quite awhile and since they were so low I had to pull my emergency brake all the way up to the top to get my car to not roll. I replaced my pads last week and now I still have to pull the ebrake handle all the way to the top. If i pull it 1/2 or 3/4 of the way up the car will roll back in my drive way. My drive way is maybe a 5 -7% incline it is nothing. What can I do to fix this? i was told that my cable was stretched out. If it's stretched out can I even fix it, or does it have to be replaced? Thanks everyone. Any info will be greatly appreciated.
dustin
Old Nov 13, 2007 | 12:25 PM
dream_G35's Avatar
not sure if there's a DIY around for this but yea, our cars e-brakes suck badly. I never trust it, my solution has just been e-brake/leave in gear combo. to be safe....
Old Nov 13, 2007 | 12:43 PM
G35fromPA's Avatar
The cable can be adjusted:
Also, you do realize that the e-brake doesn't engage the rear caliper pads, right? It uses separate brake shoes inside the rotor.
Old Nov 13, 2007 | 12:49 PM
Yv12345vY's Avatar
^^ Great find!! Should be a quick and easy fix just don't make it too tight.
Old Nov 13, 2007 | 12:52 PM
G35fromPA's Avatar
It's not a find - I have the service manual and uploaded the pic...
Old Nov 13, 2007 | 01:02 PM
skyhorse's Avatar
thank you very much for that -- i honestly had no idea that the ebrake did not use the pads. i figured that was why i had to pull it up so high -- maybe I will do what dreamg35 said leave it in gear and pull the ebrake -
i will tighten the cable on thursday, i am installing my spacer on thursday anyway. thanks again for the post out of the service manual
Old Nov 13, 2007 | 01:07 PM
skyhorse's Avatar
what is the first picture of, it won't pull up, it only shows the infamous X
Old Nov 13, 2007 | 01:09 PM
G35fromPA's Avatar
Same thing as the attachment.
Old Dec 10, 2007 | 01:21 AM
Godzilla35's Avatar
is this the same for adjusting the ebrake on the automatic? i cant even get my cable to grip sometimes when on a big hill in N... i was told to let the car go in neutral with the ebrake on, let off brake, then park... to bypass stress on the parking pall....?...
Old Jan 24, 2008 | 06:23 PM
jserman's Avatar
good find... do you know if it is the same for the Z????
Old Jan 24, 2008 | 06:39 PM
crashnburn's Avatar
yea, how u do it with the pedal e brake? my doesnt hold at all in my 03 5at... hasnt 4 over 2 years now
Old Jan 25, 2008 | 09:33 AM
waijai's Avatar
i.love.gold
Adjusting the e-brake on the 5AT should be the same. I disassembled my ebrake on one side when I replaced my hub and wheel bearing. Just turn the star adjustment piece to tighten up the e-brake shoes.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
