recommended tire size for stock 18"s 03 coupe rear
looking to get some wider tires for stock 18"s i know 245-45-18 is standard for rear but does anyone have mabye some 275-30-18 or anything close? pics of your setup would be helpful, wanted to see how wide i can go and how it would look, and i have stock suspension, thanks
Tire selection......!
If you want to go larger on the back of the G you need to find a size that is
close to the same height.......30s won't work! 265/40X18 is probably all you
can use with the OEM 8" wide wheel. You could use 245's on the front end
that seems to work well........give the TireRack a call and get there opinion!
Originally Posted by akk08
how bout 255 35? anyone have this setup?
What are your concerns with the tires?
TWASkyliner
Feb 8, 2020 08:00 PM
