Need Assistance Diagnosing a Few Noises..
Old Nov 15, 2007 | 10:56 PM
Canadian's Avatar
Canada, eh?
Over the last few months I've noticed my car has started to make two noises that are actually quite annoying...
The first is a squeaking noise that happens when I first get into the car, and then it will just continue to squeak randomly when I'm driving, but it does it all the time. When I go over any sized bump the car will squeak. What could this be? I think it could be something with my Stillen Sways, as I've heard that when your endlinks go bad they start to squeak. If this is the case, how do I fix this?
Second, one day I was parking the car and I had it in reverse. I noticed that I could hear a very fast rattling sound, almost sounded like a grinding noise, but it was more of a rattle. Ever since then I've noticed a big loud rattling sound coming somewhere from between the passenger seat and the shifter. I've got under the car a few times and had my friend look at it, and we can't figure out what the rattle is. I hope its not my tranny..but I have no idea how to figure out if it is.
Now, I need someone to tell me what these are and how to fix them, lol. Thanks for any help!
Old Nov 17, 2007 | 05:35 AM
ElixXxeR's Avatar
1) My guess: the noise is coming from your sway bars, as you suggested, or even more likely the compression bars
Not sure about the second issue, could be a boat load of things.
Old Nov 28, 2007 | 03:02 PM
Doc_Yizz's Avatar
Is the squeaking sound similar to the squeaking of an old spring mattress? My car does it and it comes from the driver's rear wheel well area. Hell, a few weeks ago it began doing it CONSTANTLY when I was driving. It was so bad it sounded like an old 1970's Chevy Pick up. Then, all of a sudden, it stopped squeaking constantly and now does it only occassionally when I get in or out of the car. I still gotta take it for a check, but I am guessing it can be a bad bushing somewhere back there...
Old Nov 28, 2007 | 03:08 PM
madchef's Avatar
Where is the squeaking coming from? Inside might be the seat rails/seat.
Under the car might be exhaust hangers.
2nd issue, possible the rear axle issue? Didn't think that applied to your car though.
Old Nov 28, 2007 | 03:46 PM
atownpdx's Avatar
try not driving the car on the third wednesday of every other month. I bet it will disappear if you do that.
Old Nov 29, 2007 | 12:03 PM
TheCrescent's Avatar
I had the same squeky/crunching noise coming from the front suspension as well. Took it to the dealer the first time and they replaced some stabilizer bars in the front. It came back in 2 months and the second time I took it in they said the suspension components needed to be lubed which they did for free since I told them it was recently replaced like 2 months ago.
Would be nice to have a DIY that shows how to lube the suspension so I don't have to take the car in to the dealer every 2 months. The noise is gone and usually happened after going over bumps.
KruZZe
Feb 27, 2023 05:04 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
mattdg35
Sep 14, 2015 11:28 AM
