Big Problem
Old Nov 16, 2007 | 10:53 PM
SteveBlake's Avatar
Big Problem
I can't figure out how to finish the DIY suspension spring install and now my car is sitting on a jack, with no front left wheel, and the shock/spring is "out of order". If i can't finish it what do i do? I don't know anyone personally who works on cars and i can't drive it anywhere because of the shock/spring....
Old Nov 16, 2007 | 11:23 PM
JOKER's Avatar
CLUB MODERATOR
what are you stuck with?
Old Nov 16, 2007 | 11:31 PM
SteveBlake's Avatar
joker can i take you up on that offer of sending me step by step instructions, that would be AMAZING, because those ones i found were very vague and skipped small things that made a big difference.
Old Nov 16, 2007 | 11:34 PM
JOKER's Avatar
CLUB MODERATOR
those are actually same as I did
No diff
ask me the Q I'll answer them for you as clear as I can.
Old Nov 17, 2007 | 11:22 AM
JOKER's Avatar
CLUB MODERATOR
how did it go man?
Old Nov 17, 2007 | 12:39 PM
JOKER's Avatar
CLUB MODERATOR
Guys help this guy out.
I suggested everything I could and he still cant get this bolt out.
He tried hitting the nut with a hammer. He's saying that bolt is soaked in WD-40 and it still would not come out.
Mine just fell right out so I did not face a stubborn bolt like that.
Any of you that done springs faced this?
This is a front sway bar bolt.
Old Nov 17, 2007 | 01:23 PM
godmans's Avatar
Soak it with EVEN MORE WD-40..
get a breaker bar and try from there
Old Nov 17, 2007 | 01:24 PM
Deezflip's Avatar
he needs one of those fork ball-joint remover. Basically looks like a fork with only 2 tapered prongs. He can easily rent one from a auto parts store.
You basically wedge that fork between that rubber cover, and the metal part that you're trying to remove it from and pound away with the hammer on the handle of the fork.
Get a 4-5lbs hammer. Those regular nail hammers are too light sometimes.
Trust me on the fork...i came across this problem many times on previous vehicles. Some of those ball joints are just old, rusted, and it eventually binds.
Old Nov 17, 2007 | 01:40 PM
Deezflip's Avatar
Sorry, i meant separator, not remover.
Old Nov 17, 2007 | 01:56 PM
JOKER's Avatar
CLUB MODERATOR
yeah but there is nothing there to be removed
The bolt is not wedged in there. It should not be that hard to remove it.
Old Nov 18, 2007 | 12:55 PM
G35JAMMER's Avatar
It looks like he only has one side of the car jacked up, thus preloading one side of the sway bar. Jack the whole front of the car use jack-stands, un-bolt both swaybar end-links at the same time.
Old Nov 18, 2007 | 01:36 PM
SteveBlake's Avatar
This guy is the winner!!! haha, sorry i didnt post earlier but i had some fellow g35drivers come over and do the fronts for me NorthsideRacing/JtranStudio
Drifter2090
Dec 26, 2015 12:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
