Problems with Toyo Proxes T1R
Old Nov 27, 2007 | 02:30 PM
WaLLy's Avatar
the only problem I had with the T1R's is one tire kept going low and it hasn't ever had any nail or been patched at all.. weird
though, the tires did last me quite alot, almost 30k miles on all four tires and I've gone to the drag strip plenty of times as well.
Old Nov 27, 2007 | 02:42 PM
g35man04's Avatar
CLUB MODERATOR
i think they just have had some bad batches of tires..
Old Nov 27, 2007 | 02:54 PM
Hexxum001's Avatar
Have the valve stem checked fellas. I had the problem of a leaky tire also. I took it back to Status. They had encountered this problem before so they knew what was wrong. They changed the valve stem and the problem was solved. I have had these tires on my Works for over a year now with no further issues. *knocks on wood*
Old Nov 27, 2007 | 02:59 PM
g35man04's Avatar
CLUB MODERATOR
yeah you better be knocking hard!! lol!! I replaced my Valvestems as well when i got the rims installed....I had the issue with the tire wear was ridiculous...both rear tires gone by 10-12k miles.
Old Nov 27, 2007 | 09:44 PM
Beebo's Avatar
the only problem i have is a leaky front tire... the tires are pretty much new so ill see how they do...
Old Nov 27, 2007 | 09:47 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I thought it was widely know that the t1r's have horribly soft sidewalls?
Yep... & get real noisy with wear.
I gave up on Toyos a few years ago.
Old Nov 27, 2007 | 10:22 PM
chester's Avatar
wat u have now intgr8r
Old Nov 29, 2007 | 10:50 PM
Silver350GT's Avatar
Yea let me know what you got as well....
Old Dec 3, 2007 | 10:36 AM
Q45tech's Avatar
Tires are only designed to be quiet until half worn at best because the tread depth is an acoustic slot designed to cancel some of the noise, as the tread wears this tuning goes out of phase and may actually increase noise.
There are several reasons why tires should be replaced when half worn. Noise and wet performance are just 2 of them.
Old Dec 14, 2007 | 02:19 PM
G35-24's Avatar
Im Running Mine On 19's. No Problems Here.
But Then Again I Drive So Hard I Go Throught Them Every 15k Or So
jilljann1
Jul 21, 2020 08:12 AM
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
mattdg35
Sep 14, 2015 11:28 AM
