So I ran over a rock a little bigger than the size of a fist on the road. I ran over it on the drivers side of the car. Both tires ran over the rock. My rear wheel on the drivers side some how managed to get bent by the rock getting between the rubber and the aluminum of the wheel and bent the wheel. So I had to send that off to big fixed.
I got that back and now the front tire seems to have a slight shimmy or wobble to it. I had the wheel balanced and an alignment after I got my rear wheel and tire back. However, I still feel some kind of wobble coming from the driver side of the car.
Is it possible that the tire on the front or back that is causing the wobble? Or do you think that is coming from a bent wheel, which in this case is most likely the driver side front wheel?
Any feedback would be good.
i.love.gold
Check your front wheel. you may have damaged something in your suspension or thrown off your alignment
