06 350z brakes on an 04 coupe(non brembo)
Old Dec 19, 2007 | 03:53 AM
sammy_G's Avatar
Would this be a good upgrade? I'm wondering if these Z parts are the same brakes that were on my 05 sedan. Those were soo much better than the 03/04 brakes that i'm currently running... again. I found a great deal on a set of 2006 350z brake calipers and rotors. less than 5000k miles
Easy swap? Anyone done this?
Old Dec 19, 2007 | 04:02 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
They are definitely an upgrade and an inexpensive one at that. They will bolt right up, you might have to get the rear 05-07 dust shields to fit the rear rotors on, or you can just cut the lip of your current dust shields
-GP-
Old Dec 19, 2007 | 04:22 AM
redlude97's Avatar
I believe the master cylinder part numbers are different as well, so that my make a difference in the performance. Not sure if they need to be swapped or not though
Old Dec 19, 2007 | 05:03 AM
They shouldnt need to be swapped, i know of atleast 2 people that have done the swap and havent had a problem.
-GP-
Old Dec 19, 2007 | 05:19 AM
redlude97's Avatar
I'm not saying it will cause a problem, but performance my not be optimal. The front calipers got significantly larger pistons while the rear caliper stayed the same while being used on a larger rotor. This shifts the brake bias and pressure distribution as well as possibly change the pressure multiplication requirement for the master cylinder.
Frankieg35
Mar 20, 2016 09:42 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
