To all the engineers out there... I need a favor!
My friend has access to a CNC machine and other tools needed to make wheel spacers... she offered to make some if I provided the metal and all the specs. That being said, does anyone have a SolidWorks or Mastercam design of a 15mm and a 20mm hub-centric wheel spacer for the OEM 19's? Also, does anyone know exactly what type of metal most wheel spacers are made of?
BTW, please don't turn this thread into a "stop being cheap and buy name-brand spacers" argument.... I trust her abilities and am confident these spacers will be as good as or even better than the name-brand ones.
Any decent engineer with the studs in hand and a pair of calipers and a micrometer could knock out a design in a few hours, the material is almost always aluminum. I seriously doubt you are going to find anyone with the spacer specs on hand though
^ yea, she said she can design it herself if need be, but i'm just trying to see if anyone already tried it... just trying to make it easier for her
all i know so far is:
5x114.3
15mm/20mm
1.25 bolt thread (correct me if i'm wrong... might be 1.5)
also, any1 know the center bore size?
and is there a specific type of aluminum i should get?
thanks!
5x114.3
15mm/20mm
thanks!
If I were you. I would not do it.
I don't doubt abilities of your friend I just don't think that it's worth the hassle.
You need to make them out of something light. So metal is not an option. You need some kind of alloy.
they must be perfectly balanced also.
With all that work I don't think you should do it.
Just buy them.
the material that they are made of is proven and not going to fall apart on you.
IMO it's safer to buy them then to make them.
Just buy them.
The hub size is 66.1-2mm, depending on where you look. The thread sizing doesn't matter for the spacer design, as for the aluminum, if she's a real engineer she should know what type of aluminum to use.
Also, they should be made on a lathe type of cnc machine, so they should be perfectly balanced from the process
An alloy is a metal
An alloy is a homogeneous mixture of two or more elements, at least one of which is a metal, and where the resulting material has metallic properties.
Alloy is an alloy. It's not metal.
What are you taking about? An Alloy is a mix of various metals, which still makes it a metal? What else would it be?
when you mix Vodka and tomato juice. Do you still call it tomato juice?
It would be an alloy.
Your reasoning is wrong, when you mix Vodka(a liquid) and tomato juice(a liquid) is it still a liquid? OF COURSE!
HAHAHA OK
Brass is any alloy of copper and zinc
