SPC front camber kit
Old Jan 11, 2008 | 02:14 PM
_GRide35_'s Avatar
Originally Posted by Gilley
You should do it yourself because a lot of so called professionals don't know what they're doing or the lights wouldn't be on.
Take off the wheel and look behind the hub. you will see where the speed sensor mounts to a metal bracket onto the hub. Directly underneath the sensor is a ring on the hub. Loosen the one bolt holding the speed sensor bracket to the hub, fix it centered on that ring and retighten the bolt. I went ahead and cleaned the rin too.
Thx Gilley I will try that, I still dont understand how the sensors were realigned by the mechanics.
Old Mar 1, 2008 | 05:51 PM
jayhoe's Avatar
Is a kit like this needed to align the caster as well? I took my car in to be aligned and the guy the caster was out of spec but there was nothing he could do without some sort of kit.
Old Mar 2, 2008 | 09:18 AM
Gilley's Avatar
Caster isn't adjustable on the stock a-arms. Most camber kits can't change caster settings, but the SPC a-arms can.
Old Mar 8, 2008 | 11:20 AM
MPK1232's Avatar
how low is your drop?
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
