Help me get lower!!!
Old Jan 8, 2008 | 12:53 PM
coffee79lincoln's Avatar
I have a 2006 sedan with 20" mrr gt-1 with 285/30/20 on the rear and I want to lower it badly but the wheels this shop sold me have an offset more suited for the coup ...seeing that I bought them a year and a half ago there not going to help me. Does anyone know if I can get away with lovering it 0.4 or 0.6 " without rub? would it help to change to 275/30/20 ? Thanks for any thoughts on the situation.
Old Jan 8, 2008 | 12:57 PM
35bills's Avatar
What's the offset they gave you?
I think the best way is to either go with adjustable coilovers or revised 350Z springs.
Also,
Old Jan 8, 2008 | 12:58 PM
G35Papa's Avatar
What offset are you running on the rim and whats the width?
Old Jan 8, 2008 | 03:03 PM
its a 10" wheel I measured theoffset at 2.25 inch which I think converts to 57mm does that sound accurate? sorry I'm new to this
Old Jan 8, 2008 | 03:21 PM
BuckeyeG's Avatar
No that doesntsound right at all. If they are more a coupe offset they would be more like a 20-35 offset. Sedan is more of a 38-45 offset.
Old Jan 8, 2008 | 03:36 PM
sorry its a 45 offset
Old Jan 8, 2008 | 04:44 PM
ttrank's Avatar
Grocery getter
A +45 with a 285 is going to be very close to rubbing, even with rolled fenders. It will depend on how much negative camber you have. You can try 350Z springs or basic lowering springs then switch to a 275/30 if they still rub.
Old Jan 8, 2008 | 08:47 PM
5150DS's Avatar
If you are looking for a half inch drop, try the coupe springs. The Z springs will be closer to a one inch drop.
Old Jan 9, 2008 | 01:43 AM
solopresident's Avatar
teamsolo.net im-integline
new rims
Old Jan 9, 2008 | 07:05 AM
I need a new tire in the rear because of a nail through the side wall so It would probably make more since to order 2- 275/30's instead of getting another 280 and having it rub when I drop it ...or is the general Idea that I should just get a better suited set of wheels instead of dealing with the chance of having an issue?
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
