switch: 04' Brembo's on 07' Coupe & 07' OEM on 04' Coupe
Old Jan 11, 2008 | 06:58 PM
redlude97's Avatar
Originally Posted by fast04G
are you talking about swapping from a g35..or a g37? im sry i assumed a g37. their brakes r what im talking abouit. sry for confusion and me being an idiot
Those aren't made by brembo either, they are made by Akebono and they are larger than the OEM brembos.
RBull's Avatar
Rated M
^either way the brakes from an '08 G35 or an '08 G37 they aren't Brembos, as others have stated.
Old Jan 11, 2008 | 06:59 PM
RBull's Avatar
Rated M
they need to be with the extra weight.
Old Jan 11, 2008 | 07:34 PM
App6MT's Avatar
Littering and...
Hey redlude, do you have any information regarding 03-04 Brembo's vs. 06?
Any place I could read and not bother you
Old Jan 11, 2008 | 07:37 PM
redlude97's Avatar
What information do you need? There isn't alot of detailed information out there, just stuff I've gathered from various threads throughout my time here. The front rotors are almost exactly the same size, while the rear brembo rotors are larger
Old Jan 14, 2008 | 12:07 AM
PieroG35's Avatar
04' Brembo to 07' swap
Thanks Gilley for the info.!
Redlude97 can you confirm that the master cylinder would need to be changed? I don't know what the master cylinder is so I'm lost.
Has anyone actually done this swap?
Old Jan 14, 2008 | 10:47 AM
mwarsh1's Avatar
the master does not need to be changed.
Old Jan 14, 2008 | 12:53 PM
redlude97's Avatar
I cannot confirm that it needs to be changed, all I know for sure is that the part numbers are different between the brembo's and 06's. This may or may not be a problem, it will work with either but its hard to know if the system is working optimally with the other master cylinder or not
Old Jan 14, 2008 | 02:20 PM
lowrider's Avatar
Originally Posted by Glex25
The brakes on the 07 G35 are OEM Infiniti brakes.
The brakes on the 08 G37 are made by Akebono.
Close - G37 brakes are generic Infiniti - The G37S is Akebono.
Lou
Old Jan 28, 2008 | 04:43 PM
PieroG35's Avatar
Instead of cutting the dust shields can I just switch them?
Old Jan 28, 2008 | 05:25 PM
redlude97's Avatar
Yes, but its somewhat difficult from what I understand
Old Feb 15, 2008 | 05:09 PM
PieroG35's Avatar
Local Infiniti Dealership says the swap can't be done! I'm not really sure why. They started by talking about how the suspensions are completely different. I'm not sure why it would matter?
Does anyone know of someone who has put OEM Brembo's on an 06'/07?
Old Feb 15, 2008 | 06:04 PM
Gilley's Avatar
Brembos will fit on the 03-07 coupes , but you will have to remove or cut the dust shield. The suspension doesn't matter. I even put the OEM brembos on my 03 G35 sedan. I bet you dealer would really say that's impossible. I had to cut the rear dust shields though.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
wonderizm
Sep 24, 2015 03:09 AM
NemesisGee
Aug 11, 2015 07:10 PM
mushu
Jul 15, 2015 03:55 PM
