Are these H&R spacers right?
Old Jan 17, 2008 | 08:39 PM
GThIrtYFiZle's Avatar
I just received the H&R spacers and they don't have the shoulder. Its a 5mm flush spacer. Is this the right one?
Old Jan 17, 2008 | 09:34 PM
redlude97's Avatar
5mm spacers don't need a shoulder since they aren't thick enough to cover the entire hub. They should center on the hub though
Old Jan 17, 2008 | 09:40 PM
I thought these would have the shoulder so that i could put the hub ring on it and the tire would sit on that, but theres no shouloder. Is it cause they are 5 mm or are these the wrong ones.
Old Jan 17, 2008 | 09:42 PM
These are it!!!! So will the wheel still center on the hub or will it be lugcentric? Cause I just installed the hub rings in order to make them hub centric and it deffinitely feels better. Is there space for the hub to go on and so on
Old Jan 17, 2008 | 09:44 PM
redlude97's Avatar
You should still be able to fit your hubcentric rings onto the portion of the hub that extends past the spacer
Old Jan 17, 2008 | 10:04 PM
Thanx red lude. I will try this out tom.
Old Jan 18, 2008 | 07:38 PM
Jason@Riverside's Avatar
5mm spacers are hub centric to the wheel hub, but NOT hubcentric to the wheels...
I do not recommend using them...
The smallest spacer that is hub centric and wheel centric is the 10mm Eibach spacer...
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
