Upgrade To Sport Springs?
Old Jan 22, 2008 | 02:59 PM
TIRE_SMOKE96's Avatar
So I was installing my Tein S tech springs this weekend but ran into a problem with the front struts. I got the strut off of the car and then compressed the spring. To my suprise the threads on the top of the struts shaft is rusted! Well I used WD40 and alot of elbow grease and wrenchs to take off the nut but failed. So since the nut wouldn't come off I decided to tighten it back down. WHAT THE HECK! It wouldnt budge. So I decided I will just replace the struts.
Now my question for you all is it worth it to get the sport struts or all around for the $600. Or should I just replace the front struts with OEM. Keep in mind I will be installing the Tein S Tech springs with them.
PS I think you will all be amazed as to see how well my rear tires tuck with my 275/35/19 toyos on 9.5 inch wide with a 34 offset rims.
Old Jan 22, 2008 | 03:05 PM
redlude97's Avatar
Which s-tech springs are you using? G35S/G35C/350z? IMO, you should upgrade to coupe shocks or revised 350z shocks
Old Jan 22, 2008 | 03:23 PM
Yea I guess that would help. LOL
The car is a G35 Sedan 2003 with PREMIUM PACKAGE
Old Jan 22, 2008 | 03:30 PM
redlude97's Avatar
I was not asking about the car, I was asking about which s-tech springs you purchased. That makes a difference because the springrates are different depending on the application
Old Jan 22, 2008 | 04:05 PM
Ok I will check
Old Jan 22, 2008 | 04:42 PM
Klubbheads's Avatar
go with z-shocks no matter what the springs are for. If it is for 350z, U might as well go with coilovers instead of buying new aftermarket shocks. If it is for G35 coupe or sedan z-shocks will last u for a whilleeeee. And no $600 is too high for shocks. I got z-shocks with 10k on them for $50 3 years ago and they are still holding up like new after 50k miles on them.
Old Jan 22, 2008 | 07:52 PM
Dan_K's Avatar
Koni Yellow Sports all around. Night and day difference between OEM.
Old Jan 22, 2008 | 07:54 PM
Klubbheads's Avatar
^never got the concept of spending 500-600 dollars for shocks.
Old Jan 22, 2008 | 08:11 PM
redlude97's Avatar
For better dampening and control so your springs don't bounce all over the place?
Old Jan 22, 2008 | 10:58 PM
FlyingLumpia's Avatar
Only problem with Koni, is they dont have dampening control, only rebound. If you want aftermarket, and since you dont have awd. Tokico would do just fine.
Just my 2 cents.
Also your rears are a +24. I thought when you first got them you said they were a +35.
Old Jan 23, 2008 | 12:03 AM
Klubbheads's Avatar
why not get the tein basics and have the adjustable ride?
Old Jan 23, 2008 | 01:42 AM
Just my 2 cents.
oh yea I meant 34 offset on the rears, not 24 sorry...........
Old Jan 23, 2008 | 01:44 AM
redlude97's Avatar
The dampening isn't adjustable on the basics, IMO dampening adjustment>>>>>height adjustment if you are actually concerned with performance. A good set of spring combined with d-specs or konis will outhandle a cheap set of coilovers any day of the week
Old Jan 23, 2008 | 01:54 AM
Ok since I have the Tein S tech springs and rear wheel drive I guess I will just get the Koni shocks? I am not too intrested in adjusting anything when it comes to my suspension. I just want to be able to get in my car and drive without having to worry about anything else. Thus a fair balance between fun and reliable.
Old Jan 23, 2008 | 02:03 AM
redlude97's Avatar
No, you should get the tokico d-specs. The Konis are valved for use with much stiffer springs than any of the s-techs. You still haven't told us which s-techs you are using either
