Anyone run a BBK with these 20" GT-7's?
Old Jan 23, 2008 | 04:45 PM
BadBoy06's Avatar
Car is in storage now>> winter.
I am looking at the Stoptechs 6-POT 14" front & 4-Pot 14" for the rears.
Any help would be fabo!
Here is my wheel information.
Volk GT-7
(Front) 20 x 9.5 +22 offset
(Rear) 20 x 10.5 +24 offset
Old Jan 23, 2008 | 11:54 PM
helldorado's Avatar
You'll need to do a physical check on caliper clearance on the wheel using a printout Stoptech can provide you. The offsets, particularly the rear, sound like the ones for aggressive lip / low caliper clearance which would mean high risk of a BBK not fitting without spacers.
Old Jan 24, 2008 | 12:42 PM
BadBoy06's Avatar
I got to inspect this weekend. I remember having 2 finger gap between
rear caliper and spokes of wheels when I was cleaning back there. hmmm
Old Jan 24, 2008 | 04:43 PM
helldorado's Avatar
Two finger gap is not a wheel fitment chart. Don't be lazy and careless unless you're ready to deal with the consequences as most BBK manufacturers will not take bag a brake kit if you find out it doesn't fit after you've opened the package.
Trust me. I had GT-7's with a 10.5" +24 rear and ended up replacing them once I got my AP Racing BBK because they didn't have enough space. BBK calipers are much wider than your stock ones
http://www.stoptech.com/tech_info/wheel_fitment.shtml
Look at Ray's offset chart
http://www.rayswheels.co.jp/cgi-bin/...?modelName=GT7
Old Jan 24, 2008 | 05:51 PM
BadBoy06's Avatar
I'm not lazy or careless, car is not with me at this time (storage.) I will however pull the wheels off this weekend.
What size spacer did you have to go with?
And thanks for the other info!
Old Jan 24, 2008 | 09:50 PM
helldorado's Avatar
I hear you. Just seen a lot of other people underestimate and figure they have enough room and find out the hard way, including myself.
I didn't use a spacer, I bought new rims because I wanted more clearance and didn't want to push that +24 offset out to something like +14. We estimated that a 5 mm might work but 10 should've done it.
Thebaws11
Jul 2, 2021 11:36 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Cbohannan101
Sep 12, 2015 10:32 PM
n2fooz
Sep 4, 2015 07:46 PM
G35CO
Sep 4, 2015 09:27 AM
