30k mile brake service
Old Jan 26, 2008 | 04:28 PM
kenempireex's Avatar
I have 06 coupe, non-brembo. My front set still have 6mm, my rear set only has 2mm left!!!! Nissan dealership is quoting me $368+tax for replacing the rear pads and surfacing the rotors. Isn't that too much? I can almost get new aftermarket slotted rotor + brake pad for that price. I eventually want slot rotors or BBK within the next two year.
If I just replace the pad will that be okay? The dealership was telling me about viration.
Old Jan 27, 2008 | 02:46 PM
any ideas?
Old Jan 27, 2008 | 03:30 PM
bigugly78cj5's Avatar
woah...yea that seems stupid high... i know ford offers front or rear brake jobs for 199 with ford/motorcraft pads and resurface.... yeaa yeaa its an infiniti but really its still just brakes... id try a nissan dealer maybe if u wanna stick with oem stuff..if not go aftermarket...brakes are a peice of cake and do it yourself..... 2mm u still have some time to decide....not much so dont take to long...
Old Jan 27, 2008 | 03:49 PM
G35sedan03's Avatar
Try this site http://www.g35parts.com/9083/osc/index.php?cPath=58 you can get oem parts fairly cheap, or this one http://www.trademotion.com/partlocat...?siteid=213775 should be able to get what you need cheaper than that.
Old Jan 27, 2008 | 04:41 PM
do i need to surface the rotor too?
Old Jan 27, 2008 | 05:43 PM
Jason@Riverside's Avatar
PM me for some rear pad pricing...
any time you put new pads on you want to re-surface the rotors...
Old Feb 6, 2008 | 01:20 PM
G-MENTED's Avatar
if there are no grooves on your rear rotor, you can lightly sand it down to clean it up.
Old Feb 8, 2008 | 10:45 PM
Petoria's Avatar
how do you check/measure how much brake pad is left?
Old Feb 11, 2008 | 10:18 AM
G35fromPA's Avatar
If there are no grooves, and you're not changing pad compound, resurfacing isn't absolutely necessary. If you really want to be sure, lightly sand with medium grit sandpaper and wash rotors with soap and water, and then do a good bed-in.
Gip
Aug 24, 2015 05:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
RedBaronK
Jul 27, 2015 06:25 PM
mjfenix
Jul 17, 2015 02:07 PM
