I know everyone has Tokico D-Spec Shocks but...
Old Jan 27, 2008 | 07:15 PM
Mr Inkredibul's Avatar
What about these? Are these bad? I just need shocks that are good enough for 350Z H-Techs. I don't need them for the track. What does everyone think?
http://cgi.ebay.com/ebaymotors/TOKIC...spagenameZWDVW
Old Jan 27, 2008 | 11:07 PM
5150DS's Avatar
I am curious myself. I have looked at my350z to see how the z ones rate, but was unsuccessful.
Old Jan 27, 2008 | 11:24 PM
redlude97's Avatar
your stock shocks will be good enough for h-techs, those might be valved slightly stiffer than stock
Old Jan 28, 2008 | 10:43 AM
waijai's Avatar
i.love.gold
Hmmm not a bad price...might pick some up to use with my air suspension.
Old Jan 28, 2008 | 08:39 PM
dklau33's Avatar
Yes they have been talked about over on my350z before but not much. They are the lower line of Tokico shocks/struts that are basically meant for OEM replacement but with better valving. They obviously have no adjustability. I'm not sure how the G35 model is valved (ie sport or non-sport shocks) but if they are more like the sport shocks they will be plenty fine to match the 350Z H-Techs which have only a slight increase in spring rate. Here's Tokicos own description on the product.
Originally Posted by Tokico
Also offered are the Tokico HP's, aka the "Blue's". These are a replacement strut, designed to be an econimical replacement for worn stock shocks, with an emphasis on performance. continues to be the overwhelming choice of performance enthusiasts looking for the best in overall handling and ride quality. The HP Series damping typifies TOKICO's valving flexibility and philosophy by minimizing low speed damping force and greatly increasing damping at medium and high piston speeds for improved compliance, tire adhesion and handling.
Old Jan 28, 2008 | 11:31 PM
so i have an 03 non sport coupe with 33,000 miles. Someone said I will be able to go like 10,000 miles on stock shocks. Is this not true...can I use my stock shocks with 350Z H-techs?
Old Jan 28, 2008 | 11:32 PM
Old Jan 30, 2008 | 02:13 AM
dklau33's Avatar
Holy quadruple repost batman! But to answer your question I don't think there was a separate sport or non sport coupe shocks in 03. The valving of the 03 coupe shocks should be able to handle the 350Z H-Techs just fine.
Old Jan 30, 2008 | 10:14 PM
5150DS's Avatar
I am no expert, but if you are getting springs made for a 350z I would get the 350z Tokico's also. From what I understand the 350z shocks will give you additional suspension travel over G shocks.
Old Feb 6, 2008 | 05:42 PM
Triple8Sol's Avatar
Tokico blues are tried/true on many cars. The D-Specs offer adjustability in the dampening. If you don't need that, then the ones you linked will be just fine. If you're lowering more than 1", I'd def recommend getting the Z version. If not, then it prob doesn't really matter.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
DRG35R
Sep 16, 2015 05:33 AM
TheBay
Sep 3, 2015 03:27 PM
