Front Camber Question
went to get a wheel alignment saturday & the guy told me i need a camber adjustment for the front. i'm sitting on g35 h-techs.
the guy told me that there's some kind of way by using a longer bolt or something like that to adjust the front. but i thought i heard that you had to replace the c-arm on the g35 from somewhere or somebody.
Did he tell you what the specs are up front? Chances are that you are out of spec, or just not at optimal specs. But the camber shouldn't be bad at all with a g35 h-tech drop. Certainly not bad enough to need to replace the a-arms IMO.
kinetek
Aug 3, 2015 04:25 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
