Brembo Brake Swap?
Old Feb 7, 2008 | 02:25 PM
louieallthetime's Avatar
Brembo Brake Swap?
I have the 5at coupe and Im looking to put the brembo brakes on because I can get the calipers fairly inexpensive and dont have the money for a 5 grand endless kit lol... what else do I need other than the calipers to do the swap correctly?
Old Feb 7, 2008 | 02:26 PM
Nismo G's Avatar
Mounting brackets, rotors, SS brake lines, correct pads and thats it.
-Sean
Old Feb 7, 2008 | 02:33 PM
Boston's Avatar
Out of curiousity, where did you find the inexpensive calipers? I've been looking myself. Thanks
Old Feb 7, 2008 | 02:35 PM
redlude97's Avatar
-Sean
There are no mounting brackets, but you do need the front?(or rear, can't remember) mounting bolts from the brembos.
Old Feb 7, 2008 | 02:40 PM
Nismo G's Avatar
No brackets on our car? Are you 100% sure about that? Doesn't make sense, but ill take your word for it. The bolts have to be bigger then.
-Sean
Old Feb 7, 2008 | 02:41 PM
redlude97's Avatar
-Sean
Yes, the "brackets" are built into the caliper
Old Feb 7, 2008 | 02:45 PM
redlude97's Avatar
Old Feb 7, 2008 | 04:25 PM
Nismo G's Avatar
^ very cool! Well i guess he will need a different bolt, but it doesn't even look like he will need that...
-Sean
Old Feb 7, 2008 | 09:00 PM
There's a place near my town that is basically a G junkyard. Anything and everything and the guy owns a body shop/paint shop. He rebuilds the ones that are in minor wrecks and parts the hell out of the other ones.
So wait...if that's all I need are rotors and SS brake lines which ones should I order? Any other parts?
Old Feb 10, 2008 | 02:17 AM
nothing???
Old Feb 10, 2008 | 01:33 PM
sammy_G's Avatar
be sure to get some decent brake pads like endless or hawk hps
i'm intrigued by the 'junkyard' pm me details
Old Feb 10, 2008 | 04:43 PM
jjyellow's Avatar
You will need four bolts for the rear caliper b/c they are gonna be different than the non brembo brakes
Old Feb 10, 2008 | 11:09 PM
gdragon's Avatar
+1 and remove the non-brembo rear dust covers...hope this will help
Old Feb 11, 2008 | 09:15 AM
I think I might just have the guy at the place install them with some endless brake pads ill order. He said he'd charge like 150 bucks to do it.
Old Feb 11, 2008 | 10:21 AM
G35fromPA's Avatar
You can get some decent rotors from g35parts.com (Centric rotors) to fit the Brembos, or you can find many choices for slotted/drilled (like dba 4000XS) and do a search for choice of brake pads. For the street, I'm partial to the OEM pads, but others like the Project mu NS and the Nismo pads as well.
