Whose got aftermarket end links?
Originally Posted by bigc
I have an '05 which was supposed to come with the beefier endlinks so I thought I was ok. A week after putting the bars on I started to notice clunking at slow speeds over bumps though. If a relube doesn't work I'll replace the end links.
Originally Posted by n1cK
after installation, you should verify the correct alignment of the endlink, meaning that it must be parallel to what it is attached to (ie - sway bar or arm). if not, they may not be able to fully attenuate as designed thereby causing some sort of "noise."
Originally Posted by OH6 G35
Do you mean "perpendicular"??
Originally Posted by 06PlatinumG
What don't you like about the SPL's??, I just bought some and am going to install in a couple of weeks
Stillen Sways with adjustable end links.......?
Chris from what I've read we won't realize how well aftermarket sways work
until we find adjustable end links. A few members have had them for sale but
only one set which won't get the job done, I need both front and back with
the same links. I'll keep emailing different companys until I find what will work
for our cars.
Gary
for our cars.
Gary
#30
for our cars.
Gary
for our cars.
Gary
You can contact Kuah (at SPL Parts) and Adam (at Z1 Performance).
Both are very knowledgeable and are very helpful too!
