Tein + EDFC installation...
Old Feb 12, 2008 | 08:14 PM
cke73's Avatar
Can anyone let me know the range of labor charge for the Tein + EDFC installation and a good professional none rip off shop in the SF bay area? Do I need camber kit if I want to lower it to approximately a finger gap with 18" wheels on a 03 sedan? Thanks!
Old Feb 12, 2008 | 08:32 PM
G35Papa's Avatar
From stock height to a finger gap, yes, you will need camber kits front and back it you want to get it back to OEM and prevent premature/uneven wear of the tires.
You should come out to some of the meets in Norcal, we're a close group and love to talk shop and hang out.
Here's a list of shops you can call around in the bay area.
https://g35driver.com/forums/showthr...d.php?t=156204
Old Feb 12, 2008 | 11:37 PM
ttrank's Avatar
Grocery getter
The coilovers install will be just like a spring install. The EDFC will be a decent amount more. They have to install a motor on each corner and then wire/install the controller.
I did mine myself in ~5-6 hours.
Old Feb 13, 2008 | 11:19 PM
chobble19's Avatar
go to a shop that is experienced w/ g35's and with edfc installations so they know what they doing and can do it quicker. shouldnt cost more than 300
Old Feb 13, 2008 | 11:24 PM
Nismo G's Avatar
If you know how to install the coilovers just do it yourself...i did mine myself and the EDFC is pretty easy to install. You will need a friend to help you pull through the wire in the rear, but its pretty easy other than that. A shop will probably chage you 5 hours just for the EDFC...
-Sean
Old Feb 14, 2008 | 03:24 PM
cke73's Avatar
G35papa, thanks for the link. I'll call around to check out the price. Yea, I need to come out to one of these meets to meet you guys. I'll check the group meet threads.
Thanks for the other replies. But if anyone else has a price you already paid for the installation would be wonderful so I know the ball park figure. Thanks!
Old Aug 18, 2008 | 07:40 PM
spddmn124's Avatar
-Sean
can you post your edfc setup??? thanks!
KruZZe
Feb 27, 2023 05:04 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
