1st post, please no flames! spring questions
Old Feb 13, 2008 | 09:53 PM
muskamatt's Avatar
hey everyone
i just got an 04 stick g35 coupe and just talked to my friend who had totaled his 03 350z. the question here is he said he has the eibach lowering kit for his car and said he would pretty much give it to me. i know our cars are very similar but when i looked on the eibach site the product number for the z is 6364.140 while the number for the G is 6365.140.
i may be stretching my hopes here because they seem to be different but i thought i read in a sticky that you can use z springs. anyway sorry for rushing into making a thread i have been on here for a couple of weeks and have been waiting to introduce myself but i just had to figure this out asap.
thanks guys and will be posting pics of new ride and yeah just general noob questions. oh and i wanted to do a sort of comparison to the 330ci that i had if anyone is interested.
thanks guys!
Old Feb 13, 2008 | 09:55 PM
G35pm's Avatar
They should fit fine. The spring rates for the Z kit and the G kit might be different. I would guess that the Z kit is stiffer.
Old Feb 13, 2008 | 10:06 PM
muskamatt's Avatar
thanks man, where in SD are you from? i go to school in SB but home is in north country SD.
oh yeah one last question.....this one has been debated i did my search and its like 50/50.....would i need a camber kit?
Old Feb 13, 2008 | 10:54 PM
madscientist's Avatar
there are some differences
there are some stickies in the suspension forum you should read before you begin slapping random suspension parts on your car
Old Feb 13, 2008 | 11:52 PM
Roguewolf's Avatar
Z springs tend to be about an inch lower for coupes and .5'' lower for sedans other than that they should fit.. U will def feel it lowered tho. Enjoy
Old Feb 14, 2008 | 02:16 AM
FlyingLumpia's Avatar
Other way around .5 for coupe and 1 for sedans.
Old Feb 14, 2008 | 02:24 AM
dofu's Avatar
20 Year Member
I don't know how much that set-up will drop your car, but if you drop your car more than 2", then yes, you need a camber and toe kit (the toe is more important than the camber) at least for the rear. Otherwise, it's still nice to have but not necessarily needed.
Old Feb 14, 2008 | 04:29 AM
G35pm's Avatar
Definitely fix your toe at least. SPC makes some good toe parts.
I have all the camber/toe parts on my ride but I'm dropped about 2 in. Haven't bought any tires for 20k. Due for rears, fronts have plenty of tread. Make sure you have an alignment shop in mind that will actually touch your car and its suspension parts.
Grew up in Mira Mesa, now living in Linda Vista.
Old Feb 14, 2008 | 01:06 PM
Roguewolf's Avatar
I thought coupes were heavier therefore lower.. ? maybe i misread.. or just screwed up..
Old Feb 14, 2008 | 02:42 PM
This is from a sticky in the forums.
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z. For sedan owners, the same applies to you, except you will gain a additional 1”, not just ½”
I think its because the Z sits lower than a coupe which sits lower than a sedan.
Old Feb 15, 2008 | 09:30 AM
Roguewolf's Avatar
i stand corrected
Old Feb 15, 2008 | 10:45 AM
GreenGoblin's Avatar
The goblin resurrection
You will be fine go for it
Old Feb 15, 2008 | 11:56 AM
muskamatt's Avatar
thanks guys i appreciate it. yeah i definitely have a really good alignment shop. my dad has a 65 corvette that we installed rack and pinion steering on and it went from a nightmare into perfect alignment. ill definitely check out that toe kit too
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
pxlds
Jul 30, 2015 01:31 PM
