From sport suspension to tein h-techs?
Old Feb 13, 2008 | 10:05 PM
French87's Avatar
I currently have an 05 coupe with sport suspension and was curious how much 350z h techs will lower me? Is sport already lower than non-sport suspension?I've heard they lower .8 in rear which sounds like what I'm looking for but need to know if the drop is the same on sport suspension.
Old Feb 14, 2008 | 05:54 AM
French87's Avatar
anyone?..
Old Feb 14, 2008 | 06:54 AM
r0csfinest's Avatar
I had an 05 with sport suspension and had h-techs. They do lower the car. I had 1 finger wheel gap in the front and 2 in the rear
Old Feb 14, 2008 | 03:19 PM
French87's Avatar
but thats about what i have now? i have 20's though, did you have 19?
Old Feb 14, 2008 | 03:24 PM
patman530's Avatar
If you have 20's you should probably look into springs with a lower drop. I think with the Z H-techs, the gap will still be pretty big with 20's.
Old Feb 15, 2008 | 05:43 AM
French87's Avatar
wouldnt the gap be smaller with 20's than with 19's.... i mean, bigger wheels and tires fill the wheel well more?
plus, from what ive read, Z h-techs are just about the only kit that wont require camber kit...
Old Feb 15, 2008 | 08:53 AM
r0csfinest's Avatar
No I have 20s also.
If u want a bigger drop get the Z s-techs. That's what I'm doing
Old Feb 15, 2008 | 08:59 AM
ig3507's Avatar
how is the quality on the z h-techs compared to the sport suspension?
Old Feb 18, 2008 | 04:52 PM
patman530's Avatar
the 20's also raise the height of your car, so you will need extra drop to compensate
Old Feb 18, 2008 | 04:54 PM
patman530's Avatar
assuming you're referring to quality of the ride, it is pretty similar... slightly stiffer, but hardly noticeable
Old Feb 18, 2008 | 04:56 PM
redlude97's Avatar
Not if you get the correct tire size, 245/30/20 and 255/30/20 have diameters almost exactly the same as OEM 225/40/19's
Old Feb 18, 2008 | 04:57 PM
redlude97's Avatar
this is incorrect if the proper tire size is chosen, see above
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
R350k5
Oct 1, 2015 08:41 PM
Jyounya
Sep 12, 2015 04:03 PM
Jyounya
Sep 12, 2015 02:29 PM
spanky99l
Sep 7, 2015 12:46 AM
