Question for all the lowered G's on 20's
Feb 16, 2008 | 09:06 PM
I'm not going to wade through millions of threads by searching, so I thought I would ask directly:
If you are on 20's, max width and have a drop, how much of a drop did you get before you get rubbing on turns and bumps?
I'm debating whether I should get the Sprint Suspension springs. They have a 1.8"/1.8" drop and I'm afraid that will cause more problems than enjoyment.
I currently have 20" x 9.5" rims on my G. Not 100% sure about the width, will have to check, but I just told them to max out the lip.
Lastly, any suggestions for springs are welcome. My goal is to drop it as much as I can without having rub issues.
Reply 0
Feb 18, 2008 | 01:41 AM
anyone? need advice on what spring to use for lowest drop with 20's without rub issues...
Reply 0
Feb 18, 2008 | 01:43 AM
without offsets, there is no way to answer your question
Reply 0
Feb 20, 2008 | 09:47 PM
They are +20 and +25. 20 x 8.5 and 20 x 9.5.
Anyone got a similar setup that's got a good drop without rub?
Reply 0
Feb 21, 2008 | 04:29 AM
What size tires? You have skinny wheels, so you should be just fine.
Reply 0
Feb 21, 2008 | 04:41 AM
275 on back 245 on front
Reply 0
Feb 22, 2008 | 12:14 PM
with those offsets you can pretty much dump it without problems
Reply 0
Feb 23, 2008 | 02:10 AM
you might need to roll your rear fenders....i had mine rolled
Reply 0
Feb 23, 2008 | 09:17 AM
I think anyone putting on 20s and even mildly dropping should roll fenders. Takes the guesswork out of "WILL IT FIT?"
Reply 0
Feb 23, 2008 | 11:50 AM
how much does rolling them cost on the g35?
Reply 0
Feb 23, 2008 | 01:00 PM
I am running a 285 in the rear with a 1.7in drop and 20 offset and have no rubbing issues.... I don't see why you would have any issues with that set up at all....
Reply 0
Feb 23, 2008 | 02:01 PM
i talked to some guy who said they put the same wheels on another coupe and an H&R coil over setup with a 1.7in drop all around w/o any rubs and issues, so that's reassuring.
thanks for all the input people, looks like i'll plan on getting those sprint suspension springs
Reply 0
