SPC Front Arms
Old Feb 23, 2008 | 05:30 PM
Algy's Avatar
SPC Front Arms
I recently got these arms installed on the front of my 2006 G35. I had all the lights come on and everything and couldnt get them to turn off even with an alignment. I came across a thread and notice some have got the lights turned off by just taking off the spacers. I took all 4 spacers off and the light went away when i drove off. But 2 min later into driving it popped back up again?!?!?! whats up with this?
UPDATE
Finally got everything working properly now! *sheesh* My father and I lifted up the car and were trying to realign the sensor once again and notice that the magnetic strip around the wheel bearing hub on the driver side got scuffed and a piece of it was ripped of causing the ABS sensors to not be able to read a part of the wheel as it was spinning. GOSH! we had to buy a new one which ran us $194 and once we installed it back and realign the sensors, everything worked like a charm. But we also had to stick a small small rubber washer between the ABS sensor screw to the wheel hub cause it to close to the magnetic strip causing it to make the passenger side go off. But everything works now.
Thanks everyone for trying to help me out. Now i can ROCK ON!
Old Feb 23, 2008 | 11:16 PM
Algy's Avatar
Bump
Old Feb 24, 2008 | 04:34 PM
Algy's Avatar
anybody??
Old Feb 25, 2008 | 03:35 PM
Algy's Avatar
can anybody HELP me?!? Damn lights are super annoying and plus it keeps going wack cause of the ABS!
Old Feb 25, 2008 | 04:08 PM
Roguewolf's Avatar
umm i don't know the exact really but u can try an ecu reset..? there are ways of doing it by turning ignitions etc etc or unplug ur battery overnight.
Old Feb 25, 2008 | 08:23 PM
Calvin's Avatar
Overglorified Altima
were the abs sensors replaced back to their original positions? sure there isn't any damage to them?
Old Feb 26, 2008 | 12:32 AM
Roguewolf's Avatar
yea i was thinking it's sumthin with a sensor (duh) so either reset it or maybe as O RLY stated it is damaged.
Old Mar 3, 2008 | 01:41 AM
Algy's Avatar
Im pretty sure the ABS sensors are not damaged. How could they be? All we did was take them off and switch them to another position... then took the spacers off and put them back to their original position.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
cbax
Aug 17, 2015 07:41 AM
Fireman07603
Aug 9, 2015 06:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
