Sway Bar End Links
Old Jun 30, 2009 | 10:56 AM
  #46
Vrod-Mike's Avatar
Originally Posted by Beebo
Which did you buy?
I bought these:
http://z1auto.com/prodmore.asp?model...ng&prodid=2886
Old Jun 30, 2009 | 11:55 AM
  #47
Swivel's Avatar
Moderator
Originally Posted by OH6 G35
Here is a "comparison" of SPL Parts (L), Stock (M) and PowerGrids (R).
The spherical ends on the SPL do look more robust compared to Powergrids which look to be simply cast and tapped; I'd go with the SPLs if and when I eventually do so. I don't like the angles created by even my mild drop.
Old Jun 30, 2009 | 12:25 PM
  #48
OCG35's Avatar
The benefit of the Power Grids is they’re sealed… the broken ones in this thread are the first I’ve heard of… I’ve tracked with mine and driven very spirited – lowered quit a bit (for a sedan) and so far no break.
Old Jun 30, 2009 | 03:08 PM
  #49
tblazing's Avatar
ok so im looking into buying the Hotchkis sway bars and just to clarify new endlinks are needed but 05+ endlink will work fine and will solve any issues i might have (unless dropped) over my 04 endlinks also my car is a DD so it will be on the middle setting for front and back if it makes a difference
Old Jun 30, 2009 | 04:14 PM
  #50
Vrod-Mike's Avatar
I have the Hotchkis sways with PowerGrid end links. I have mine set on the stiffest setting and mine is a DD as well.
Old Jun 30, 2009 | 04:17 PM
  #51
spinn's Avatar
I've got a Hotchkis f/r sway bar setup, but I haven't experienced the endlinks breaking; the rear endlink mount has broken before. Is there an aftermarket supplier for better mounts?
Old Jun 30, 2009 | 04:18 PM
  #52
Swivel's Avatar
Moderator
Good point.
Old Jun 30, 2009 | 04:59 PM
  #53
tblazing's Avatar
is it necessary though to up go after market or will the 05+ ones hold up to the added stiffness
Old Jun 30, 2009 | 05:49 PM
  #54
lil_will's Avatar
Same question.
I am lowered and running Hotchkis sways... do I need aftermarket or will the 05+ "beefier" end links suffice?
Old Jun 30, 2009 | 05:50 PM
  #55
Vrod-Mike's Avatar
I can't answer that question, but I figured since I was dumping so much into the suspension already why cut corners on the cheapest parts?
Old Jul 15, 2009 | 07:28 PM
  #56
silverbulit's Avatar
Originally Posted by 425skyline
So went under to adjust the end links a bit, since the car got raised a bit and I wanted to make the bar more parallel to the ground when in normal position. Put the wrenches on to loosen the end link and pow... I got the PowerGrids and never touched them after installing them and having them professionally adjusted/checked soon after.
I hope I can get a replacement. And to all others: careful with these, apparently they can be a little fragile.
I still dont get the Adjustable Endlinks and Camber Toe deal. Thats why I lowered my ride with Tein H tech instead of S tech. I heard lowering your G more than 1 inch could effect the suspension.
Anyways, how the hell you suppose to adjust those enlinks properly. Do they come with a manual? Like adjusting it to certain point depending how low you drop your ride. You know? Instead of guesstimating when adjusting. Like specs from engineers that **** will be done the right way. Checked out what happend to 425skyline Endlinks. I dont think it suppose to do that. That look like the endlink experienced alot of tension from the suspension system.
I might have to talk to one of our performance shop on my area about this type of setup, because Im planning to drop my ride more than 1 inch instead of .60inch in the near future. I just hate going down there, because somtimes I ended up spending alot of green because of those damn sales people.
Old Jul 16, 2009 | 08:19 AM
  #57
idrive_MD's Avatar
That's really interesting. I looked into these because of all the hype, found the supplier of the ball joints, THK. They have various models which come in differing metals for strenght vs cost purposes. So I'm curious which style PowerGrids went with (cheapest to maximize profit or strongest to justify price)?
Here are some links from THK:
See page 3
Ball link main menu
I looked into this to see if it was possible/cost effective to just build my own using the same THK links as PowerGrid. Looking into it I was going to use the AL series as it had some higher elongation numbers which might prevent breaking in the cast area which really seems like the only weak point of their cast design. If I were to build my own knowing the concern of the cast housing, I would actually seek out a weaker adjustment bolt hoping it would absorb the flex and not translate it into the casting which I assume is what might be happening with the PowerGrids. Those are just my thoughts on it.
Old Jul 16, 2009 | 12:06 PM
  #58
It's all about balance
I think those Endlinks are pretty good. I think if you dont adjust it right it could fail. Thats why Im wondering if theres some kind of manual or measuring tool you could go by to properly adjust them. I figure if youre off one side you can shift alot of stress on the other side causing equipment failure. I think youre pretty much adjusting it blind if you have nothing to go by. Like if you need to tighten a particular bolt you have a torque wrench and torque spec. that you can follow to properly tighten the bolt and also the instruction will limit you from over tightening it damaging the trends.
I dont care how strong and tough your Endlinks are if it's not adjusted properly it will not work in unison with rest of the suspension system. You probably end up transferring the stress on the different parts of the system causing other parts to fail. I think all those parts should be balanced.
Old Jul 20, 2009 | 10:14 AM
  #59
idrive_MD's Avatar
That is certainly a good direction to look into.
FYI for anyone interested, I was just quoted a price for the AL10 series from THK and it came out to about $40 for four of them to do the rears. I'd still have to source an adjustment bolt though.
Old Jul 20, 2009 | 12:19 PM
  #60
bert039's Avatar
Damnnn thanks for doing the leg work!! Let us know what you do with the adjustment bolt. It looks like you would just need a threaded rod and two locking nuts.
