question about dropping
Old Mar 18, 2008 | 12:09 AM
MikeYo's Avatar
i just went back to my 03 coupe and recently bought tien s techs. My car has 94,000 miles on it. im wondering what i should be replacing with the drop. i know shocks, sway, and struts.. anything else i should worrying about? let me know.
Old Mar 18, 2008 | 01:55 AM
chopstixx's Avatar
let me know how nice the ride is after the lowering
im gettin the comfort sport coilovers
with cusco sway bars
and greddy strut bar
Old Mar 18, 2008 | 11:10 AM
MikeYo's Avatar
any suggestions?????
Old Mar 18, 2008 | 11:13 AM
lov3rboy408's Avatar
www.search.com
Old Mar 18, 2008 | 11:19 AM
MikeYo's Avatar
any experiences with high milage lowering?
Old Mar 18, 2008 | 11:52 AM
sliderg35's Avatar
If you are lowering, you should also put in some adjustable camber arms so you don't fry your tires.
Old Mar 19, 2008 | 02:28 PM
MikeYo's Avatar
I'd need camber/caster kit for the 1" drop??
Old Mar 19, 2008 | 06:48 PM
tjlazer's Avatar
Yes a camber kit will help reduce tire wear.
Old Mar 19, 2008 | 07:49 PM
MikeYo's Avatar
i dont mind negative camber, thats why i dont put the 20" i have on.. im just going to run the stock tires and get them switched every 3000 miles. even if i have to buy new tires its way cheaper for 18"s then for 20"s. i guess my real question is how long will my stock springs, struts, and sways last after ive put 94k on them already.
Old Mar 22, 2008 | 10:05 AM
express705's Avatar
Originally Posted by lov3rboy408
who the **** are you to tell him to search? you dont even have 100 posts. go back to the welcome section.
Old Mar 26, 2008 | 07:43 AM
Gilley's Avatar
It won't matter if you use your 18s or 20, the tire wear will still occur with increased negative camber. An inch drop will increase negative camber by about -.8 degrees. It's cheaper to buy camber kits and install them.
Old Mar 26, 2008 | 08:02 AM
MikeYo's Avatar
I understand camber and how it works. I don't mind running -1 degree of camber. What I'm saying with not putting the 20's on because with negative camber there will be increased tire ware but it will be cheaper to replace 2 rear 245/45/18 as opposed to 2 285/30/20's
Old Mar 26, 2008 | 08:04 AM
dvsmeth0dz's Avatar
I don't think replacing your sway bars are more important than camber and toe adjustments. Imo I'd do shocks and a camber kit. Then you would be able to roll on the 20's w/o worrying about uneven tire wear.
Old Mar 26, 2008 | 08:10 AM
GreenGoblin's Avatar
The goblin resurrection
There is no need to replace the sways. If anything you shocks will start to go eventualy. I would look into the rear camber kit, ebiach kit it was pretty cheap
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
pxlds
Jul 30, 2015 01:31 PM
Soumilg
Jul 18, 2015 12:33 PM
