My suspension feels weird
Old Mar 27, 2008 | 05:12 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by JOKER
I'm not putting any used parts on my suspension.
Okay...but the parts you have on your car now are used.
Old Mar 27, 2008 | 05:14 PM
JOKER's Avatar
CLUB MODERATOR
so why replace them with same ****?
Old Mar 27, 2008 | 05:16 PM
Jeff92se's Avatar
Red Card Crew
Because they should have 1/3 the miles you have now. And because it would be a really cheap way to find out wtf is wrong with your car. And if it fixes it, you would be good to go for awhile.
Old Mar 27, 2008 | 05:18 PM
JOKER's Avatar
CLUB MODERATOR
how much?
Old Mar 27, 2008 | 05:20 PM
Jeff92se's Avatar
Red Card Crew
Let Triple8sol chime in with the mileage first.
Old Mar 27, 2008 | 05:24 PM
kenchan's Avatar
Wouldn't that make car jump more and be more rough on the road?
jump more... not sure wat you mean, but the D-Spec is adjustable from
softer than stock to much stiffer than stock so the only thing that would
force your car to jump is if your springs are stiff.... meaning over 550lbs/in.
just adjust damping to match your spring rates and should be pretty smooth.
Old Mar 27, 2008 | 05:29 PM
JOKER's Avatar
CLUB MODERATOR
When car hits the bump and spring compresses car stays in one place cuz spring is compressed.
If the spring is not compressed then the hole freaking car jumps up.
Old Mar 27, 2008 | 05:44 PM
Jeff92se's Avatar
Red Card Crew
Actually if the shocks are that stiff, the suspension would tend to stay compressed and the would just "thunk" down. IMHO, you would have to have those D specs on full hard on to get them to do that.
Old Mar 27, 2008 | 05:50 PM
Swivel's Avatar
Moderator
Almost sounds like 'bump steer' like they used to get on old solid-front-axle hot rods. When you hit a bump, it actually slightly changes the direction of your tire (I think someone suggested something like this due to rear toe). But if Tito's feeling it on a stock car, that doesn't make sense.
Joker, was it happening before you put the bald rear tire on?
Old Mar 27, 2008 | 05:51 PM
redlude97's Avatar
Sounds like bump steer actually, and is somewhat inherent in all lowered suspensions
Old Mar 27, 2008 | 05:55 PM
Jeff92se's Avatar
Red Card Crew
Bumpsteer is when the lower control arm becomes parallel or worse when the suspension compresses. Yes, something that lowered cars have. Not sure if Joker's springs are actually that low.
Old Mar 27, 2008 | 05:56 PM
JOKER's Avatar
CLUB MODERATOR
there were diff weird things happening after I installed new springs.
Maybe it's me just getting use to aftermarket springs and all that
Old Mar 27, 2008 | 05:58 PM
JOKER's Avatar
CLUB MODERATOR
what's Bump Steer?
Old Mar 27, 2008 | 06:02 PM
redlude97's Avatar
bump steer/toe steer/roll steer is the result of different pieces in the suspension geometry travel in different radius arcs as the suspension compresses.
Old Mar 27, 2008 | 06:08 PM
  #30
Jeff92se's Avatar
Red Card Crew
http://www.panteraplace.com/page135.htm
Ugh, it might be the fact that the steering rod gets too long then too short as the supension compresses. As the rod gets parallel, it effectively gets longer, thus artically steering the car.
OEM suspensions are designed so that the control arm and tie rods are almost always NOT parallel. But when you lower the car all bets are off.
On old school 510s, you could order bump steer spacer that went inbtween the lower control arm and strut to restore the oem control arm/ tie rod angles.
