best rotors for the buck?
Old Apr 7, 2008 | 08:07 AM
04Gwhiz's Avatar
hey guys,
I am interested in getting rotors..I know there are many manufacturers and I can get cross drilled/slotted etc..what do people here use and where can I get good prices for them? i have an 04 g coupe with brembos
Old Apr 7, 2008 | 01:22 PM
5150DS's Avatar
I have these and am happy with them. Don't forget to paint the rotor surface (both sides) with a light coat of high temp paint before installing them to help inhibit rust.
http://www.r1concepts.com/
Old Apr 7, 2008 | 01:53 PM
cyco's Avatar
Thanks for the tip on R1!
I just ordered rear pads and rotors from them
Old Apr 7, 2008 | 03:13 PM
G35fromPA's Avatar
If you're going slotted/cross-drilled, these are a great bang for the buck and will stand up to hard track use too:
http://www.autoanything.com/brakes/6...0A2540460.aspx
Old Apr 7, 2008 | 03:40 PM
5150DS's Avatar
The op said he wanted a good price. I know those rotors are great and the multidirectional air flow internally probably keeps them cool, but you can get front and rear from R1 for what one front costs from DBA.
Old Apr 7, 2008 | 03:58 PM
Q45tech's Avatar
Centric premium series [black hat] neither drilled nor slotted.
http://www.centricparts.com/prod02.htm
Old Apr 8, 2008 | 12:36 AM
5150DS's Avatar
Those are the same rotors as the R1 premium rotors except for the drilling and slotting on the R1's. No argument from me.
Old Apr 8, 2008 | 02:51 AM
in2win's Avatar
best bang for the buck was the stoptech stage 2 setup i went with, 547 picked up. Included slotted rotors (could have gotten drilled and slotted and just drilled) with Axxiss ceramic brake pads ands stainless steel brake lines. My braking is much better now, dusting about the same and rotors still look new after 3 months. I was worried about rust but havent seen a bit. I have a new respect for stoptech (rotorworks) products.
Old Apr 9, 2008 | 12:46 PM
Q45tech's Avatar
On the street rotor and thus pad temperature is purely a function of rotor weight and the thermal conductivity of rotor cast iron and how well this heat is transferred to the wheels.
Watch out for spacers and any changes [rust corrosion] between rotor hat and wheels.
Better rotors will usually require heavier rotors, If you want pads/rotors to operate 10% cooler you will need 10% HEAVIER ROTORS.
Simple to calculate rotor temperature rise. Car weight x speed = ft/pound/secs SQUARED = kinetic energy.......etc etc stop by 60 pounds of rotors [in 3 seconds] for accuracy do it for each wheel due to weight distribution and changes.
When you've finished you'll find that the brakes have 2 times more horsepower than the engine can create
Old Apr 16, 2008 | 06:08 PM
G35fromPA's Avatar
Interesting...those R1 premiums are priced quite well...will have to look into those when the time comes.
Do you notice any increased ambient noise or vibration through the pedal with the slots? Or any decrease in bite?
Old Apr 16, 2008 | 09:11 PM
5150DS's Avatar
When I first got the rotors I painted the surface to help avoid rust in the drill/slots and unswept area of the rotor. I was unimpressed initially, but I think this was because the paint had transferred to the pads. Since then they feel good, but I have not made any emergency stops to really try them out.
Old Apr 24, 2008 | 01:09 PM
FlameOn's Avatar
Thanks, I wouldn't be painting mine.
I got a good price from R1. $423 total for all 4 premium series rotars and ceramic brake pads. I'll swing down there and pick them up soon.
Do I need to change my brake lines, or the ones we have are fine?
Old Apr 24, 2008 | 01:30 PM
SxExCx's Avatar
Good luck with R1's...search my threads
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
